Old 04-15-2003, 06:29 AM   #1
full foot notch
what bags and cupmounts for a 75 C10
alright, im planning to bag a 1975 Chevy C10 SWB that im about to buy, and im somewhat unfamiliar with the 2wd Chevy stuff, so i was wondering, with a fullsize 2wd, do i use a 2500 bag or a 2600 bag,cause since its 2wd it would tend to make me believe to use 2500, but since its a fullsize would it be better to go with the 2600, and can i use bag cupmounts made for the S10 with the C10, cuase i found a site that had blueprints for S10 cup mounts, or do i need to use cup mounts made for a 1500 series pickup, of course im going to use a 3 inch drop spindle with the setup, and is it worth it to get the DJM tube control arms that are lowered cup mounts, cuase i was hearing that if you use the spindle and control arm drop setup, that the control arm cup is going to hit the ground when trying to spark
sorry if there is any confusion
or if someone could show me pictures of how the front is setup, possibly thier airbag setup in the front
and out back im going for a 12 or 16 inch notch, so im most likely gonna run a 3600 bag outback, now thats gonna be fun to do
this will also be posted in the 73-87 section
full foot notch is offline   Reply With Quote
Old 04-15-2003, 10:55 AM   #2
Izzy
Trucker.
Izzy's Avatar
You'll need a 2600lb or F6873 bag for our trucks. The cup size on an s10 is too small for our trucks plus it's got a hole different bolt pattern since it uses the 2500lb bag.
You cannot combine drop arms and spindles on any truck w/out violation scrub laws. You'll end up ripping those arms off as they are normally the first thing to hit the deck when laid out.
Why such a big notch? You can lay out w/ as small as a 9" notch. If you do that big a notch you're goign to put uncessart stress on the frame.
You should think about running a F9000 Tapered sleeve bag for the best travel/ride on the rear of our rigs. It'll give you just short of 9" of lift.
The only other route I'd go other than a tapered F9 would be a leveraged or cantilered F6873(2600).
Izzy is offline   Reply With Quote
Thread Tools
Display Modes
