10-13-2011, 09:53 AM | #1 |
fuel sending unit
A little help or advise: I'm running a Blazer fuel tank set up on my 72 short wide. Have a 350 TPI under the hood supplied by a external Summit Racing fuel pump. Is there a sending unit out there I can use that utilizes a internal fuel pump that will fit my application. Thank you in advance for all your help.
Tex (USAF) -72 C10 SWB--bagged on 22" -79 Mini Cooper pickup--on hold -95 Chevy Dually Crewcab--tow-rig -06 Magnum Hemi RT--wifey's -06 Yamaha R1--fun times |
10-13-2011, 10:29 AM | #2 |
Re: fuel sending unit
I put a TPI in a '71 using an '85 2.8 TBI S10 blazer tank. It fit OK and I used the sending unit that came with the tank. I just swapped the pump from a TBI to a TPI pump. If the depth of the tank is similar it might work in an earlier tank too.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
10-13-2011, 12:26 PM | #3 |
Do you think it will work on one of the Blazer tank conversion kits?
Thread Tools | |
Display Modes | |
