Old 10-13-2011, 05:11 PM   #1
71 GMCDRVR
71 GMCDRVR's Avatar
Drop specs?
Does anybody know the exact (or ballpark) you get from doing a leaf swap to under the axle???
Thanks for the info in advance
Ryan
Blessings, Ryan G
JESUS IS LORD!!!!!!
71 GMCDRVR is offline   Reply With Quote
Old 10-13-2011, 06:00 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drop specs?
Approximately 5" drop.
This truck has a leaf spring flip.
http://67-72chevytrucks.com/vboard/s...d.php?t=488097
Keith
Convert to disc brakes.
Old 10-14-2011, 03:20 AM   #3
71 GMCDRVR
71 GMCDRVR's Avatar
Re: Drop specs?
do 3in coils and the 2 1/2 drop spindals make the front 5 1/2 in drop?? I wanna go low and take all the rake out of it.
Blessings, Ryan G
JESUS IS LORD!!!!!!
Old 10-14-2011, 03:47 AM   #4
lolife99
lolife99's Avatar
Re: Drop specs?
Yes.
Keith
Old 10-14-2011, 04:15 AM   #5
71 GMCDRVR
71 GMCDRVR's Avatar
Re: Drop specs?
Okay, so 5 in front and 5 in back= rake still there, but 3 in coils in front and 5 in flip out back = level truck. i'm planning on running my stock steelies, not sure on tire size yet planning on doing hot rod satin black with steelies and white walls. What are your thoughts on 3/5??
Had a buddy lower my first truck in highschool, he lowered it and I drove it! new to doin these things myself started by building my 383 now on to the other things. thanks for the info brotha!!
Blessings, Ryan G
JESUS IS LORD!!!!!!
Old 10-14-2011, 11:38 AM   #6
blime81
Laid Lo
blime81's Avatar
Re: Drop specs?
Only thing I would suggest would be to do a 2.5 spindle and a 1" coil up front rather than the 3" coil. Spindles give a much better ride than drop springs and if you decide to go lower later (it happens...) you'll have one less thing to buy.
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 10-14-2011, 12:48 PM   #7
SCOTI
SCOTI's Avatar
Re: Drop specs?
x2. Do spindles & trim the current coils or get 1" drop units.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-14-2011, 04:50 PM   #8
71 GMCDRVR
71 GMCDRVR's Avatar
Re: Drop specs?
This was my plan originally but my wife doesn't want me to spend too much money right now. apparently there are other more important things like a mortgage and other assorted grown up things So I'm trying to get where I want to be without breaking the bank, and since a set of coils is around 100 buck I can get a full 3" drop in the front for now and do it better down the road. And blime I havnt even lowered it yet and I'm already thinking lower so I hear ya!!
Thanks for the advice amigos, Blessing
Ryan..
Blessings, Ryan G
JESUS IS LORD!!!!!!
Old 10-14-2011, 05:33 PM   #9
SCOTI
SCOTI's Avatar
Re: Drop specs?
Ryan..
Do you already have disc brakes? If so, spend a little more for the spindles & cut the existing coils. Better ride quality. Check on one of the supporting vendor deals..... http://67-72chevytrucks.com/vboard/s...d.php?t=469597
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-15-2011, 04:52 AM   #10
71 GMCDRVR
71 GMCDRVR's Avatar
Re: Drop specs?
Does anybody have any pics of a 3/5 drop???? curious if I should just go lower right off the bat???
Blessings, Ryan G
JESUS IS LORD!!!!!!
Old 10-17-2011, 02:30 AM   #11
71 GMCDRVR
71 GMCDRVR's Avatar
Re: Drop specs?
OK you guys got me I can't find drop spindles for a 3/4 ton anywhere!
Will 1/2 ton spindles work or am I back to 3" coils????
Blessings, Ryan G
JESUS IS LORD!!!!!!
Old 10-17-2011, 05:21 AM   #12
lolife99
lolife99's Avatar
Re: Drop specs?
OK you guys got me I can't find drop spindles for a 3/4 ton anywhere!Will 1/2 ton spindles work or am I back to 3" coils????
www.performanceonline.com sells 3/4 ton drop spindles,... but they are pricey!
Keith
Old 10-17-2011, 02:16 PM   #13
71 GMCDRVR
71 GMCDRVR's Avatar
Re: Drop specs?
Thanks for the link brotha!
Blessings, Ryan G
JESUS IS LORD!!!!!!
Thread Tools
Display Modes
