drill and tap head for temp sender?
hello, who has drilled and tapped a head to install a stock temp sensor?
did some searching and never really found a how to, is there enouth room for the 3/8 pipe thread style, will I have manifold clearance? don't wanna dive in and cause myself a headache...lol or should I just buy the adapter found online |
Re: drill and tap head for temp sender?
I drilled & tapped the head on my suburban. You will need a 37/64" drill bit, 9/16" also works.
cool, and I assume there is enough clearance....
thanks |
![]() Join Date: Apr 2011
Interested in doing this on my truck...do you have to remove the head to do this?
-Steve ![]() 1980 GMC C15 Sierra LWB Dark Carmine Red/Carmine Int Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011) Now: 5.3/4L60E, 2.73 12-bolt open rear |
For $18 street and performance makes adapters for this. To me I'll spend that small amount to not risk messing up a head. Just contact them and tell them the thread size and sender length for mechanical gauge. They also make an adapter to replace the oil sender with a mechanical gauge system.
Posted via Mobile Device |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
The adapters are garbage. I drilled and tapped mine on my 6.0 Do it once and do it right. Why deal with leaky cruddy adapters?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
A bit of searching the internet will get the P/N for a sender with the right thread, or you can get a thermostat housing from a later truck with the right size hole.
Just a few alternatives... |
#9 | ||
If there are senders that have the right threads and have the right ohm range for the '91 Burb gauges I'm running, I'm all ears...did some searching and found very little info available for stock senders
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I used the adapter from Autometer, 12/1.5 by 1\8ths I think.
here it is. ![]()
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
When I built my 5.3L S-10, I went to the the auto parts store and bought a new sensor (brass I believe). Then I sanded down the threads enough to run the correct die over it. Once completed, I threaded into the passenger side head and hooked up my sensor wire. Worked for 2 yrs (25k miles) and then sold the truck.
__________________________________ 1971 GMC Stepside 350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar ________________________________ |
Still Learning
Anyone take pictures of this modification?
#13 |
Sorry, I didn't notice this was in the LS area. I was thinking about the different senders in SBC heads...
#14 |
I machined a bunch of SB temp sensors down into a 12mm/1.5 thread so that means NO adapter and NO drilling and tapping the block! Talk about doing it right. If you want one PM me for details. !IF! thats OK with the board? I just need to know which sensor you want because there are like 5 diffrent connector types.
I LIKE TRUCKS 1986 GMC Suburban Build Build link 1982 Chevy SWB 2wd Scottsdale, Build Link Sold ![]() 1987 Jimmy Build, Project Cheap A$$ Build Link |
#15 | |
Still Learning
#16 |
![]() Join Date: Feb 2004
Some drill and tap water pump i just run a mechanical gauge sender on top radiator hose
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#17 |
I never even thought about machining one down, never even considered how much extra meat was on it..... thanks I am going to take a look at it rite away
#18 |
will this work in the back of passenger head and show true temp on the original gauge cluster
http://www.summitracing.com/parts/VDO-323092/
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
#19 |
Truck and auto performance nut
the adapter made the temp sensor stick way out and look like crap...... so I tapped my passenger side head.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#20 |
#21 |
CamaroChris,
What year truck is that temp sensor for? I have a 72 and the sensors are 1/2 NPT and I couldn't find any sensors that I could turn down enough to work. Later vehicles use a 3/8 NPT with a different resistance and wil not work with my factory guages.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#22 |
The picture I posted is a 91 3/4 ton temp switch. I have also turned down an 86' I'm going junk yard hopping this weekend to grab a bunch of other year temp senders to play with.
#23 |
if you find any 72s that you can turn down ill take one or two.
#24 | |
![]() Join Date: Feb 2003
I could take some basic ohm readings before and after also. I can't believe the gauge companies haven't jumped on this. I guess the $ is in selling us gauges not senders. |
#25 |
I ran across this link that uses the large block plug tapped for the 1/2" NPT sender. It's not as good as having it in the head, but it's only a few inches away. http://ls1tech.com/forums/conversion...r-adapter.html
1-Drill and tap the head 2-Drill and tap the water pump 3-Add a short pipe with a fitting in the upper radiator hose 4-Tapping the block heater/drain plug 5-????????? 6- Find or get someone to make a 12mm 72-88 Ohm Resistance At 220 Deg F sensor(If it's even possible) I've cut open a few senders and the large senders use a large wound spring and the smaller ones use a thin flat spring. Last edited by Chevy4Life; 11-30-2011 at 05:45 PM. Reason: Fixed incorrect info! |
Thread Tools | |
Display Modes | |
