10-17-2011, 09:17 PM | #1 |
Installing Power Brakes
Members,
I am wanting to install power brakes to my 72 GMC. Can anyone lead me in the direction of where to buy the parts and how hard the install is. Thanks, James |
10-18-2011, 01:10 AM | #2 |
Re: Installing Power Brakes
performance online sells a kit.
I just bought all new stuff from them to swap out my old stock power drumbrake setup. It should be here by the end of the week. I can post up some info when it arrives if you would like. I purchased the below items.. Booster & MC Kit Front Power Brake Line Kit Disc conversion kit Scott |
10-18-2011, 02:37 AM | #3 |
~Rest In Peace~
are you keeping the rears a drum setup or disc brakes too
i got mine from cpp
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
10-18-2011, 07:22 AM | #4 |
If you are gonna keep the current configuration[drum,drum] it would be a matter of pulling the m/c loose from the firewall. After that you would be ready for the booster install and then bolt the m/c back up to the booster.
There was a write up about two weeks ago on someone that went to a booster system and did'nt break the lines loose or anything like that so no bleeding was needed. It appears to me it is as simple as replacing the m/c because you just unbolt and place the booster in between. Then all that would be left is to plumb it by adding manifold vaccum |
10-18-2011, 08:08 AM | #5 | |
10-18-2011, 11:18 AM | #6 |
Grandpa in the rustmobile...
You have the right MC and PROPORTIONING VALVE CURRENTLY.
Just get some brackets from the board/junkyard and a booster, if the booster is good then your lucky paint it up and run it, it its bad well you've saved yourself the $ for a core
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-18-2011, 11:57 AM | #7 |
Sorry, still half asleep when I posted, but he still should have all he needs exept the booster, line,and brackets
10-18-2011, 02:40 PM | #8 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=221598 Looks pretty straight forward to me...I like easy! Oh, and another thing.....Welcome to the board! |
10-18-2011, 08:23 PM | #9 |
Thanks,
It does have disc front and drum rear. So I can use my current master cylinder and by a booster. Then after install bleed everything correct? |
10-18-2011, 09:05 PM | #10 |
Eat, Sleep, Drive a Chevy
Welcome to the site from Texas!
If you will take the master loose from the firewall, and dont take the brake lines loose you wont even have to bleed the lines. Just slip the booster in between and bolt it all together.
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
10-18-2011, 09:26 PM | #11 |
67-72 parts collector,…
Just buy a 71-72 booster.
Look here in the classifieds to get the correct mounting bracket. (You might even find a booster also)
Thread Tools | |
Display Modes | |
