Old 10-18-2011, 01:39 PM   #1
69Time1
Exhaust Question
I have a 350 in my 69 GMC (after market motor 74') On my exhaust manifold (driver side) there is a lever. Does anyone know what the lever is called and what it is for? It appears to adjust the exhaust flow..
69Time1 is offline   Reply With Quote
Old 10-18-2011, 01:46 PM   #2
70-Chevy
-Chris
70-Chevy's Avatar
Re: Exhaust Question
A lever? Im not familiar with exhaust manifolds too much as I've always had full length headers. Do you have a photo by chance? Im curious to see if this "lever" is at the front of the manifold by the #1 cylinder. I've seen some guys use newer model manifolds and cut and smash the end of the O2 sensor instead of removing it and plugging the hole. Its alwasy looked like a lever to me when I've seen them do that.
Im sure someone on here will be able to help you out.
70-Chevy is offline   Reply With Quote
Old 10-18-2011, 01:50 PM   #3
kwmech
The "lever" manifold should be on the right hand side of the engine. It is a 'thermostat' so to speak, it closes when cold allowing exhaust to back flow a little up through the intake manifold to help with heating up the carb to help reduce emissions. More often called a heat riser valve
Old 10-18-2011, 02:07 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
heat riser ==ex wife both have been removed
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 10-19-2011, 10:44 AM   #5
69Time1
Thanks ya'll.
Thread Tools
Display Modes
