Old 10-18-2011, 09:52 PM   #1
FL71C10
Will this serpentine belt setup work?
I found someone local parting out a 1990 Blazer. It's got a 350 in it. I made a deal with him for the serpentine belt setup including the ac compressor, alternator, ps pump, and water pump. Here are pics. Can anyone tell me if this one will work?
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-18-2011, 09:57 PM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: Will this serpentine belt setup work?
I have used them on many older rigs.
Get the water pump & fan too and it will work on an older small block, they are reverse rotation from the non-serpentine stuff and don't interchange.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-18-2011, 10:00 PM   #3
FLEET72
FLEET72's Avatar
It should be fine, I'm setting up one from an 89 Suburban.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 10-18-2011, 10:05 PM   #4
FL71C10
Yep, I'm getting those too, plus I think I'll grab the rad hoses just because I know those are tough to find sometimes and then I'll have one to try. I figure I'll replace the water pump, but it's good to have the original.
Thanks for the fast reply.
Anybody need any other parts off this truck?
Old 10-18-2011, 10:07 PM   #5
FL71C10
I can use my existing harmonic balancer, right?
Old 10-18-2011, 10:13 PM   #6
gearys 5600
gearys 5600's Avatar
I have that same setup on my 69, it works great..
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 10-18-2011, 10:19 PM   #7
Jarwood
Jarwood's Avatar
Here is how mine is set up. The previous owner set it up. I can get info on it if your interested.
Jarwood is offline   Reply With Quote
Old 10-18-2011, 10:29 PM   #8
FLEET72
FLEET72's Avatar
Yep, the same.
Oscar
'95 Jimmy 4X4
Old 10-18-2011, 10:30 PM   #9
FL71C10
Thanks!
Old 10-18-2011, 11:07 PM   #10
Pkh66
Works on my Chevelle!
Pkh66 is offline   Reply With Quote
Old 10-19-2011, 08:46 AM   #11
FL71C10
Will I need to get new hoses made? Do the ones on this newer setup have metric threads?
Thanks again to all who helped.
Old 10-19-2011, 10:04 PM   #12
FL71C10
OK, I went and pulled the serpentine setup off the truck tonight. That was fun! I didn't realize that I had to get a puller to remove the ps pump before I could get to the last bolts for the brackets on the driver's side. So off to Pep Boys as it started to get dark. I think I buggered up the damper pulley because I didn't realize the harmonic balancer pulley bolt needs to come off before I could take off that pulley. I bent it getting it off, so i guess I'll need another one of those. I finished in nthe dark, but that's par for the course.
Now I'll have to pull my old accessories off the motos and make the swap. At least the front clip is off and I can just pull the core support off to make it easier.
Does anyone know if the ps pump fittings on this pump are metric, or will I be able to use my old pressure hose? The truck I took it off of had a separate power steering pump cooler. so the return hose won't work.
Thanks again to all who provided advice.
Old 10-20-2011, 01:15 AM   #13
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
The late model pump's pressure fitting has a different thread and design, but... the whole thing unscrews from the reservoir and can be replaced with the one from your old pump. I found the pressure hose from a 67 Chevelle worked very well and threads directly into our boxes. I've done this swap on both Screamin and the Malibu and its very easy. Be careful not to lose the spring loaded check valve just behind the fitting.
You will also need to rewire your alternator, so I hope you grabbed the pigtail with the alt. I provided a schematic for this as well... again its very easy and totally reversible... you dont even need to cut or mutilate any wires in your harness.
If you want to go all out, beings you have the clip off..... the lower schematic is how I have my vehicles setup with headlight and fan relays, it works flawlessly.
screamin_c10 is offline   Reply With Quote
Old 10-20-2011, 03:47 AM   #14
stich626
nice,
stich626 is offline   Reply With Quote
Thread Tools
Display Modes
