Old 04-15-2003, 10:15 PM   #1
Nelson
Milled Heads
I have a set of 441 Heads that were milled 20-30 thou. I plan to use these to replace my 882's! Do I have to get my stock Intake manifold mill too, or could I get away with thicker Head gaskets? Also, would these milled Heads have clearance issuses with the values (have stock pistons & cam).
I'm no expert, so any help would be appreciated.
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 04-15-2003, 10:32 PM   #2
lngbed71
Nothing fits but the oil
lngbed71's Avatar
I think I would have the intake shaved about .015 or so. Since I can't see an exact millage number on on your heads (you say 20-30) It would be difficult to pin point an exact milling for your intake. Stock pistons, stock cams and shaved heads are generally not a clearance problem. My experience with milled heads has been anything over .010 shaved off the heads will require further machining on the intake. Hope this helps.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 04-15-2003, 11:04 PM   #3
Nelson
Thank You.
Nelson
1970 C10 350 Auto.
A/C not Working
Old 04-15-2003, 11:17 PM   #4
bigjimzlll
bigjimzlll's Avatar
do not use a thicker head gasket...you can use thicker intake manifold gaskets though
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Thread Tools
Display Modes
