gauge cluster glass
Hi I'm wondering if the glass on the gauge cluster on my 63 is removable seems to be a lot of dust and dirt inside, I would really like to clean it if it's removable
It's Better With Nitro
Re: gauge cluster glass
Yes, the gauge cluster can be unbolted to be disassembled. Just be careful lay it face side up when removing the bezel, lens, etc., since the colored lenses of the turn signal and warning lights can fall out. I completely disassembled mine to fabricate a custom polycarbonate lens for my instrument cluster.
If it is the same as my 64, the lettering on the glass will come off if you touch it. I used colored plastic notebook dividers to replace the lenses.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
Easy Does It
there is a company -whitegauges.net that makes new gauge kits in white or black , also LED's to replace the old bulbs, I did my old truck like this and it turned out nice
Thanks for the info, lost second and third gear on t350 last night glass cleaning will have to wait a little bit
two things to check, vacuum modulator, have you lost the connection and or kickdown cable maladjusted...for a start anyways.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Thanks for the info that's the first thing I checked, had it towed to my tranny guy I'm waiting for his call !!!
Hi,
find attached a very good explaination for the gauge cluster removal (1964-66). I think for a 1963 it's similary. http://www.earlyclassic.com/tech.asp...64-66%20Chevy2 greetings from Germany Martin |
Thanks Banno that will really help good info
1965 dash cluster put of dash, pics
dunno what the differences are... or if those will help, but there they are. -W |
Thread Tools | |
Display Modes | |
