Hook up a tach to a 6.2
Don't feel like researching. It's one of those little Sunpro tachs I took from my Blazer because I converted to a tach-in cluster [that I made using the same kind of Sunpro tach]
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
Re: Hook up a tach to a 6.2
It's been a while since I researched it, but I think to hook up a tac on a diesel is pretty spendy. IIRC there are 2 ways to do it...mechanically off the vacuum pump or electrically off the alternator. I can't remember what exactly is involved trying to hook it up mechanically I just vaguely remember it has to do with the pump. Electrically, there is a gizwidget you can buy that attaches to the alternator.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
I think you can just put a hall effect sensor or maybe even a magnetic pickup on the balancer they use them to read rpm on any thing that spins. Ive seen something of the sort adapted to old machining equiptment.
this would be for a digital read out of course
I'm far from an expert but I have read quite a bit on it. You should search in the 6.2 section of dieselplace.com : http://www.dieselplace.com/forum/forumdisplay.php?f=20
Here is one way: http://www.dakotadigital.com/index.c...128/prd128.htm Another: http://www.dakotadigital.com/index.c...rod/prd129.htm Autometer makes a medium size tach that has a strap that goes around the alternator to get a signal. They also make a 5" diesel tach that comes with the sensor that reads from the ballancer etc. Tinytach makes a digital tach but I don't think its round like a normal tach. |
Wow I never knew it was this much of a PITA.
Gentleman Jim owner x2
![]() Join Date: Oct 2010
It's because of the lack of electrical output to make the engine run. I made a hybrid sender out of my vacuum pump and an HEI distributor like on dieselplace.com, but they're tricky and take a good day's worth of work to get it done.
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
Thread Tools | |
Display Modes | |
