Old 10-21-2011, 04:34 PM   #1
81Stepper
Cracked Frame ( Brackets and Reinforcements Needed )
What would you do? Just weld something ON TOP?
81Stepper is offline   Reply With Quote
Old 10-21-2011, 04:45 PM   #2
maskale
Re: Cracked Frame ( Brackets and Reinforcements Needed )
that weld is crap, clean it all of and put a good backing plate. on it.
or a new truck.
maskale is offline   Reply With Quote
Old 10-21-2011, 04:50 PM   #3
81Stepper
or a new truck.
i AGREE IT IS! iT WAS LIKE THIS WHEN i PICKED IT UP 2 WEEKS AGO.
A plate on it shoul do the job?
Old 10-21-2011, 05:13 PM   #4
spudz
spudz's Avatar
I seen one cracked right there and it was from a bad front end colision. Maybe the frame was straightened and wasnt repaired correctly? I would be looking for a frame personally.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 10-21-2011, 05:14 PM   #5
81Stepper
Its just going to be a truck to take to dinner and stuff like that no hardcore offroading...
If I went with a new Frame where would I get one and how much?
Old 10-21-2011, 05:17 PM   #6
spudz
spudz's Avatar
here is the one I saw and it was from a front end wreck
Old 10-21-2011, 05:18 PM   #7
81Stepper
ok ok they fix it?
Old 10-21-2011, 05:19 PM   #8
spudz
spudz's Avatar
no the guy that bought it put a new frame under it.
Old 10-21-2011, 05:23 PM   #9
81Stepper
how many hours would swapping a frame be?
How much for a frame?
Old 10-21-2011, 06:08 PM   #10
98layinframe
98layinframe's Avatar
are you a good welder? do you have a nice 220V machine? Easiest thing to do is take it to a frame shop, have them check to see if the frame is twisted, bent or diamonded in anyway... if it is they straiten it, and ya weld the crack up solidly. Those few booger welds sitting on top the metal is not a solid weld in any shape or form.
98layinframe is offline   Reply With Quote
Old 10-21-2011, 06:12 PM   #11
81Stepper
Can they Straighten it with body on truck?
Old 10-21-2011, 06:22 PM   #12
beasst
beasst's Avatar
Yep. Gage it, pull if needed then they would weld it up. Ive done several when I worked at a frame shop. Take a couple of hrs to set up, gage, pull if needed and weld up
beasst is offline   Reply With Quote
Old 10-21-2011, 06:23 PM   #13
Rogue_Alphonse
Rogue_Alphonse's Avatar
You can drill a hole at the end of the crack to stop the crack... then weld the hell out of it with a plate!
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 10-21-2011, 06:46 PM   #14
willett
Another Day, Another Dollar
willett's Avatar
why is either side of the crack flared up like that?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 10-21-2011, 07:17 PM   #15
76stepsidechevy
I'd grind all that old garbage booger weld off of there and beat that frame back into shape there and weld it up nice. Does the truck drive straight? look like everything's in decent alignment?
76stepsidechevy is offline   Reply With Quote
Old 10-21-2011, 07:18 PM   #16
spudz
spudz's Avatar
My guess is the frame rail was knocked way over from a wreck. and someone pulled it back straight.
Old 10-21-2011, 07:27 PM   #17
Goldfinger
Goldfinger's Avatar
take a monkey wrench to it cut a gash into it that goes straight through and is about 1/8 of an inch clamp backing plate and do a good long slow weld
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 10-23-2011, 01:06 AM   #18
Damien
Damien's Avatar
I agree. Have a shop check it out. Then i would plate the crack. It looks like someone already drilled a hole or it ran to a factory hole.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 10-23-2011, 01:28 AM   #19
meter swinger
meter swinger's Avatar
Thats repairable. Dont frame swap for that. Easy to straighten, then weld fishplate on. There are a whole lot of 50's trucks out there with camaro clips welded on. Speaking of fish hows the mullet festival this year? Damn i miss that gulf coast cookin.
meter swinger is offline   Reply With Quote
Old 10-24-2011, 08:34 AM   #20
81Stepper
mullet was a blast. Brantley Gilbert Friday night then Twice the Crowd for Trace Adkins Saturday.. had a nice time
Old 10-24-2011, 12:38 PM   #21
88bagedntaged
88bagedntaged's Avatar
Hit up 67_SS396, he has a CUCV blazer that has had a hard crawling life. The crack in your fram looks Identicial to what Buster has been through !
88bagedntaged is offline   Reply With Quote
Old 10-24-2011, 02:44 PM   #22
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
You need to stop-drill that better than what's there right now. The hole that's there looks like the crack is already past it. But then clean up all the old crap, bend everything back to where it's supposed to be, and weld the crack shut. Then weld a plate on both sides of it to re-inforce it.
Oh, and "Hi" from about 30 miles south of you.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 10-24-2011, 02:46 PM   #23
81Stepper
hEY MAN! its over at the Chevy dealer as we speek
Old 11-11-2011, 06:06 PM   #24
81Stepper
Old 11-11-2011, 06:38 PM   #25
Your41Plague12
Your41Plague12's Avatar
Good work. Looks much better and is no doubt safer now.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Thread Tools
Display Modes
