10-23-2011, 06:27 PM | #1 |
'84 1/2T Dumbo Mirrors
Friend of mine just recently bought the above truck and is working thru some condition issues to use it for a daily driver. The passenger side dumbo mirror was broken in it's previous ownership. We removed the outside stainless cover which had one Phillips screw holding it. From there were two 10 mm bolts that held the arm mount in place and guess it provides tension. It was apparent after loosening those two bolts that the mirror arm would not slide up and out as there seems to be a collar of some sort at the lower end that is on the mirror arm. Three bolts appear to hold the entire assembly to the door skin of the truck but they are not 10 mm size, maybe 9 mm as they are smaller than the 10mm wrench we had. With the correct size wrench is it just a matter of removing those three bolts and the outside assembly comes off or is there a "backing" plate in the door cavity that will then fall to the floor. Sorry if this is a dumb question but I'm a 67-72 guy and not that familiar with these new fangled modern trucks.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
10-23-2011, 06:30 PM | #2 |
Re: '84 1/2T Dumbo Mirrors
no backing plate as i remember, just three plastic inserts that the bolts thread into.
JESUS IS LORD 87 crew cab V30 454/400 |
10-23-2011, 07:48 PM | #3 |
Parts and more parts
If it is done right, there is an arm or rod inside the door on one of the bolts to transfer the flexing and vibration from the mirror to the inside panel. Otherwise you would stress your outside panel and then it would crack. I know my truck has them.
Frank |
10-23-2011, 07:56 PM | #4 |
Thanks for the replies. From the looks of the truck I would think it is pretty much unmolested and pretty well neglected also. By removing all three bolts from the outside mirror mount to the door will that allow the rod or bracket to fall or is it fastened at the inner panel? Hope to change the mirror without having to remove the inside door panels right now.
10-23-2011, 08:08 PM | #5 |
Robert Olson Transport
the bolt that sits closest to the vent window has a bracket thats kinda shaped like a question mark. this holds the outer and inner parts of the door sheetmetal together. As long as that is properly bolted into the inner door , it shouldnt move too far that you could just poke it into position with a narrow screwdriver or awl if it moved. the other bolts are held in by a fitting that is now part of the door skin,, kinda like a compression deal. most of these trucks like to rot away with neglect, but hey as much as you 67-72 guys like your genre we love these old squarebodies.. and therye just as much fun to restore as your trucks
10-24-2011, 09:55 AM | #6 |
Thanks again for the replies on the mirror question. Will get with my friend later today and see if we can put that info to use. Trying to get him to join up on the board, maybe this will help. My brother-in-law (old wagon) finally joined after I talked to him several times. He has a '83 1 ton dually, 4x4, 454, 4 spd. "Bigger is Better" I guess, LOL Guess I'm the "odd man out" of the three of us with a '71 4x4.
10-26-2011, 04:36 PM | #7 |
Just wanted to say thanks again for the replies and the help on the dumbo mirrors. Went like a piece of cake, changed out the mirror and had time to down a cold Bud Light all in about 10 minutes.
Thread Tools | |
Display Modes | |
