help i need power steering
ok so when i did the swap i put headers on instead of manifolds and now i i cant mount the power steering pump how did you remount the power steering pump with out the bracket
Re: help i need power steering
Make a spacer.
Can I get pics please
Posted via Mobile Device |
I had to go to a salvage yard to find this piece. It is a support bracket you will need. Other wise, the pump will flop around badly.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381 |
#6 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You can see one in jdheff1982 picture he posted.
A guy on here I think "Justins 76" made a spacer out of washers....just stack a bunch up and it works....well at least it worked fine for him
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Ok I was going to cut the existing bracket to set back further cause the headers won't allow to go back I am still running an ac compressor right above it
Nah don't cut it, a spacer is much easier, they even make a corrected bracket for headers for around 20-25 bucks
http://67-72chevytrucks.com/vboard/s...d.php?t=433465 check out post 13
Rather than use a million washers, go to the hardware store and get some 7/16 nuts to stack up. The opening is just right for a 3/8 bolt to pass through. Stack up the nuts to get close then use washers to make up the rest of the space. Less to fall on the ground if you ever have to take it apart.
1977 GMC Sierra Grande |
Thread Tools | |
Display Modes | |
