2002 2500HD Crew Cab doors intermittently won't open
Occasionaly, the door locks on my truck will refuse to budge, and it turn, the doors cannot be opened. Most of the time, it is my passenger door lock on cold mornings. When you push unlock on the key fob or switch panel, it will barely move and then return to fully locked, and if you try to unlock it manually, the actuator will not move. You just pull on the linkage and when you let go, the indicator will return to the locked position. This morning, my driver's door decided to do the same thing. Luckily for me, my passenger door lock was working properly today and I was able to crawl over and get out. I thought nothing about it before because my passenger door lock is weak even when it does work, but this is becoming a serious problem with my driver's door not opening this morning either. Any help would be greatly appreciated, I really do not want to be stuck in my truck.
Thanks, Andrew.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
#16876
Re: 2002 2500HD Crew Cab doors intermittently won't open
bmp
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
Thanks for the bump, Sillyoldman. I havn't had this problem for awhile, so I think it may have been from the truck sitting at the dealer lot and the locks hadn't been used for so long.
I finally figured this out a couple days ago! My door locks are "popped" (broken out and sitting inside the door) and so when the windows are down the window presses against the rod sitting inside the door. Now I just have to remember to roll my window down before getting in/out of the truck until I finally decide to get my locks fixed! Lol
Thread Tools | |
Display Modes | |
