11-03-2011, 09:25 PM | #1 |
1963 chevy pickup starting problem
i have a 63 chevy truck and it has a problem with the starter when you turn it over it just go's clunk the motors not frozen and the battery fully charged and it has a new starter.
?please help? |
11-03-2011, 09:53 PM | #2 |
Re: 1963 chevy pickup starting problem
Is this a new problem? has it run before?
Bob |
11-03-2011, 10:03 PM | #3 |
it has ran before we started it the other day by push it and it ran great
11-03-2011, 10:03 PM | #4 |
it is a new problem
11-03-2011, 10:44 PM | #5 |
Sounds like the starter brushes are bad. The selinoid engauges but the starter doesnt turn.
11-03-2011, 11:08 PM | #6 |
ya maybe but its a new stater
11-03-2011, 11:46 PM | #7 |
Try tapping the starter with something while some one else is turning the ignition switch. If it cranks the engine than its the starter. If in doubt take the starter off and have it bench tested where you bought it.
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
11-04-2011, 12:16 AM | #8 |
a bad battery cable could be the issue or a corroded connection, both would present too much resistance between batt and starter.
11-04-2011, 12:39 PM | #9 |
posible
Chevrolet for life.. 1963 chevy pickup |
11-04-2011, 03:48 PM | #10 |
my 63 looks good but has problems
11-04-2011, 04:28 PM | #11 |
...just another truck junkie..
Check the battery cables, make sure there isn't corrosion and that the the negative cable is well grounded. If that's all okay then pull that starter. Just because it's a new one doesn't mean it's not a bad one. Get it tested and then you will know one way or the other. I have gotten bad starters and alternators from parts stores, it does happen from time to time.
Mike "Bear" Shea |
11-04-2011, 04:47 PM | #12 |
ok ill do that thanks
Thread Tools | |
Display Modes | |
