11-12-2011, 03:08 PM | #1 |
Gas tank again?
Out of curiosity:
Is there a reason a guy couldn't cut the botto leg off the C channel fram rail and open the widthe up to a full 33.5 inches to accept a wider tank? I would of course reweld a new angle to the outside bottom of the frame rail to give it strength. I don't like the idea of hanging a tank under the bottom since it hangs too low. A tank 33.5 x 23.5 x10 inches or so would be a perfect fit. Assuming a guy could find one that size. |
11-12-2011, 11:30 PM | #2 |
60-66 Nut
Re: Gas tank again?
A 33.5" wide tank would leave basically no bottom flange. I think if you were to add a flange on the outside like you said, that should be fine. I would extend it forward at least a couple inches past where you remove the lower flange on the inside.
Thread Tools | |
Display Modes | |
