Old 11-12-2011, 10:18 PM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
wilwood d-52 calipers
I running a 12 bolt truck rear end with astro van rotors captain fab brackets, and rear wilwood d-52 calipers for 1 1/4 rotors I having trouble with the outer brake pad rubbing the brake rotor wear the tab lines up with the bottom of the caliper, any one else have this problem or is it just me
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-12-2011, 10:48 PM   #2
rob32472
Re: wilwood d-52 calipers
hmmm I am interested to see what others say as I am getting ready to do this swap..... post a pic of issue
rob32472 is offline   Reply With Quote
Old 11-13-2011, 12:31 PM   #3
flamingbig10
6.0 powered square
The pads are rubbing were the paints is scraped off
Aaron
Old 11-13-2011, 12:36 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I would say it's just the difference in the pads that are manufactured today.
I would grind some clearance on it.
Have you looked at any other brands of pads?
Keith
Convert to disc brakes.
Old 11-13-2011, 12:38 PM   #5
lolife99
lolife99's Avatar
Could also be the rotor.
I wonder what brand CaptainFab used?
Keith
Old 11-13-2011, 12:54 PM   #6
flamingbig10
6.0 powered square
I'm using the brake best rotors from O'rielly auto parts and Ive tried the brake best pads I had for the stock calipers and the do the same thing
Aaron
Old 11-13-2011, 01:24 PM   #7
lolife99
lolife99's Avatar
I wonder if the o.d. of the rotor is larger than an oem rotor.
I find that aftermarket rotors or cheaper rotors seem to be more bulky.
I try to use Wagner brake parts.
You might contact CaptainFab.
Keith
Old 11-13-2011, 03:41 PM   #8
flamingbig10
6.0 powered square
I'm going to try a higher end brake rotor and see if it will work
Aaron
Old 11-13-2011, 04:42 PM   #9
lolife99
lolife99's Avatar
Take a tape measure,... and measure the new one before you buy!
Keith
Old 11-13-2011, 07:49 PM   #10
n2billet
Village Idiot....
n2billet's Avatar
I'm running wagner rotors and Wilwood pads on mine with no issues......
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 11-13-2011, 07:54 PM   #11
flamingbig10
6.0 powered square
I brought the rotor with me, at Orielly's and they only had the brake best in stock they said the Wagner's don't make rotors any more, and went to auto zone and there duralast rotor has a smaller outside diameter, and so I went to pepboys, but the duralast has the smallest od, I was going to return the rotors but I no longer have these boxes and I already painted the rotors.
Aaron
Old 11-13-2011, 09:50 PM   #12
n2billet
Village Idiot....
n2billet's Avatar
I went back and looked at my records and I bought Raybestos part # 397 580442R rotors on this truck, the Wagners I used on another truck.......to many projects!
Old 11-14-2011, 03:46 PM   #13
54Caddy
GM Addicted
54Caddy's Avatar
why dont you just take the rotors and machine the lip off of them easy as that
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 11-15-2011, 12:57 AM   #14
flamingbig10
6.0 powered square
I went ahead a bought some duralast rotors problem fixed
Aaron
Old 11-15-2011, 11:46 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Make sure you get this info to CaptFab. He might be able to make adjustments on his next run of parts.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-15-2011, 07:00 PM   #16
SBTork
Garage wrench
SBTork's Avatar
I assume the duralast rotors did not have the raised outer portion?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-16-2011, 01:11 PM   #17
skeeterbug
skeeterbug's Avatar
I had the same issue with the same brand of rotors brake best from oriely and wagner pads. wore the paint off my rotors just like your pic, i ended up modying the pads. will def try different rotors next time good info. The only issue im still having is having to use alot of wheel spacer to use my 15 x 10" draglites @ the strip, sucks pretty bad, scared drivers side wilwood caliper very deep. no probs when im running my street shoes (20 x 8.5 fr, 22 x 9 rear coys) of course. good luck
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Thread Tools
Display Modes
