11-20-2011, 01:10 PM | #1 |
C10 addict
67/68 Grill in great shape
The grill is off of a CST so it originally had the aluminum hoops but the are damaged. I will include the aluminum headlight buckets as well but they are driver condition with a couple dents. The grill is super straight with only 2 very minor dents the size of a dime from a grill guard. The dents are symmetric on each side. It includes the parking lights and grill brace. If you want the 1968 parking lights instead I can send swap them (the plugs are different). $120 plus shipping.
11-21-2011, 03:12 PM | #2 |
C10 addict
Re: 67/68 Grill in great shape
ttt
Posted via Mobile Device |
11-21-2011, 11:17 PM | #3 |
I am interested in your grille. AllI need is the grille shell. Could I get a shipping quote to 67456 in Kansas. Thanks Roy
11-22-2011, 12:17 AM | #4 | |
C10 addict
I have another 67 grill that is completely stripped to the shell that I could sell. I believe it is dent and rust free but I'll double check it tomorrow. I could sell it for $100 or strip this one down for the same price. Shipping via Fedex would be $41, unfortunately this is based on dimensions and not weight. UPS was even higher. Greyhound is down right now for maintenance so I'll check it when it comes back up.
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
11-23-2011, 12:30 PM | #5 |
C10 addict
I checked Greyhound and it's $50 for shipping so Fedex is cheaper. If you want just the grill shell (the stripped down one I have, not this grill) I can sell it to you for $120 shipped.
11-23-2011, 12:48 PM | #6 |
How much for the grill shipped to 89406?
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
11-23-2011, 01:48 PM | #7 |
C10 addict
I could do $150 shipped
11-24-2011, 02:09 AM | #8 |
Hi Jared, could I get a pic of the stripped down grille. $120. sounds good would just like to see a pic if that is OK. Thanks Roy
11-24-2011, 12:29 PM | #9 | |
C10 addict
I'll get you some pictures this morning. I looked it over really well and I only found one small dent on one of the grill inserts where it attaches to the support brace in the back. It's a common dent spot I've seen in these grills and should be an easy fix. I'll try and get you some good pictures of this spot. |
11-24-2011, 03:58 PM | #10 |
C10 addict
Here are some pictures of the grill (still need to pull the parking lights), I looked at it a little closer and it has a dent in the center towards the top right above the dent on the grill insert I mentioned. I'm guessing the PO probably tried to move a shopping cart or something with the truck. I posted some pictures of the lower part so you can see it's perfect, no accident or anything. If you still want it I'll knock off $20 so $100 shipped.
11-24-2011, 04:02 PM | #11 |
C10 addict
It was hard to get a picture that showed the dented area well. As you can see in the first picture, this part of the grill insert isn't visible when looking straight on. You can only see it when you pop the hood and look between the grill and core support, which is what the last picture is showing.
11-25-2011, 09:51 AM | #12 |
On the path to financial ruin!
Put me in line for the $100 shipped. I'm in Dallas, TX. Thanks!
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
11-25-2011, 03:36 PM | #13 |
C10 addict
Shipping might be a little extra to Dallas (maybe $5), the $100 shipped was to Nevada. If you send me a zip code I'll get you an exact price and if 1967chevyswb hasn't responded by tomorrow morning it's yours
11-25-2011, 05:48 PM | #14 |
75227 and that's by Greyhound right? Also, other than the dent on the top, there is no rust or pitting is there?
11-25-2011, 07:45 PM | #15 | |
C10 addict
11-26-2011, 12:40 AM | #16 |
I would be interested in the shell if it has minimal problems....little or no dents. Shipped to 75088
11-26-2011, 02:50 PM | #17 | |
C10 addict
Let me know if this works for you The only issues are those mentioned in this thread. Shipping would be the same to you, $110 shipped via Fedex. |
11-27-2011, 11:28 AM | #18 |
C10 addict
ttt....both grills still available
12-13-2011, 03:26 PM | #19 |
C10 addict
bump!
12-16-2011, 10:14 PM | #20 |
C10 addict
ttt
12-17-2011, 01:19 AM | #21 |
I'm interested in one of your grilles, which one is in better shape? I only need a shell. How much shipped to 87402?
12-17-2011, 03:47 AM | #22 | |
C10 addict
I could do $105 shipped to you for the brown grill, it's probably the better of the two because it doesn't have any visible dents on the outside, only that minor issue with the grill insert mentioned above. Let me know if this works for you |
12-17-2011, 05:09 AM | #23 |
Just a Member
I will take both... either one or whatever works
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
12-17-2011, 11:15 AM | #24 | |
12-17-2011, 12:03 PM | #25 |
C10 addict
I could do $160 shipped to you on the yellow grill. This will include the support brace, hood latch, turn signals and headlight bezels. At least $45 of this will be shipping charges I will have to pay
I'll send you a PM with payment info.
Thread Tools | |
Display Modes | |
