Old 11-23-2011, 10:24 PM   #1
Jafo20
3-speed rr
Anyone here ever rebuit there 3-speed manual trans themselves? If so ..... How long did it take and was it very hard? From a 59 truck.
Jafo20 is offline   Reply With Quote
Old 11-23-2011, 11:08 PM   #2
solidaxel
solidaxel's Avatar
Re: 3-speed rr
Don't leave any pieces out, it only comes apart one way
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-24-2011, 01:22 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 3-speed rr
Its an easy trans to rebuild. You have to be careful of not getting the needle bearings in place during assembly. The only special tool is a puller for the rear bearing. It pulls the bearing and speedo gear off. Should take about 4 hrs if you don't need parts.
dwcsr is offline   Reply With Quote
Old 11-24-2011, 02:34 AM   #4
Jafo20
Re: 3-speed rr
Will a regular gear puller work?
Old 11-24-2011, 02:35 AM   #5
Jafo20
Re: 3-speed rr
Where is the best place to buy gaskets and or rebuild kits?
Old 11-24-2011, 08:13 PM   #6
mr48chev
mr48chev's Avatar
Re: 3-speed rr
Step one is to get your hands on a factory service manual that shows diagrams and photos and gives detailed step by step instructions on how to rebuild one. The aftermarket books assume too much or don't cover it.
It's usually easiest and less messy to drain the gear oil out of the trans before you pull it.
Then I would suggest cleaning up the outside of the case and getting all the grease and dirt off it before opening it up. But that goes on any part you work on.
I haven't hunted for parts for one for years so I am at a loss on finding trans parts and gaskets out side of looking first at the regular vendors for truck parts and checking Napa and other local sources.
Nothing on Napa online but you might check with the store you go to.
Old 11-24-2011, 08:24 PM   #7
Jafo20
Re: 3-speed rr
Where can I find a factory manual?
Old 11-25-2011, 11:05 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 3-speed rr
There are some on ebay. search muncie 318 bearing kit . they cost about $90. You should be able to get a shop manual there as well.
below is a picture of a puller you need. You can make up something to do it with
Old 11-25-2011, 11:59 PM   #9
mr48chev
mr48chev's Avatar
Re: 3-speed rr
There reprinted factory service manuals on Ebay. Usually they are about 30.00.
Thread Tools
Display Modes
