Old 11-26-2011, 12:33 AM   #1
stepside-mitch
stepside-mitch's Avatar
Iv got a slight problem. HELP!
Whenever i give it gas in 3rd or 4th gear, the engine bogs. I have to constantly pump the gas pedal in order to keep it driving smooth. Iv checked the timing, rebuilt the carb and adjusted the choke a little bit. Has this happened to any of you guys? The next step is plugs and wires
stepside-mitch is offline   Reply With Quote
Old 11-26-2011, 01:02 AM   #2
pig rig
pig rig's Avatar
Re: Iv got a slight problem. HELP!
with out hearing it run and on a guess I'd start looking at your dist not advancing
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 11-26-2011, 03:46 AM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
when it bogs it usually means its running lean
what carb and engine specs please
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-26-2011, 08:31 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
i'd check the advance in the dizzy,weights move freely and the vac moves easly not sticky and drain out the fuel line from the pump to the carb(watch for crud)
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-26-2011, 09:48 AM   #5
Pork Chop
Check your timing chain
Pork Chop is offline   Reply With Quote
Old 11-27-2011, 01:39 AM   #6
stepside-mitch
Its a 305 with a quadrajet. If it was my timing chain, wouldnt the timing be all over the place? It seemed to be sticking around 4 degrees
Old 11-27-2011, 02:28 AM   #7
INSIDIOUS '86
quadra jet is opening those big throttle bores on a 305 will cause a bog, but a lean condition will cause it to choke out
Old 11-27-2011, 02:54 PM   #8
Hotrodrobert
Did this just start all at once or did it just progress?
Fuel supply can be big so check that first. Don't forget the filter behind the inlet filter on the carb. If it is dirty, it will cause just what you describe.
The coil or coil wire or the button in a HEI will also cause this problem, many other things.
Hotrodrobert is offline   Reply With Quote
Old 11-28-2011, 04:26 AM   #9
lurch115
lurch115's Avatar
i would be checking the secondary choke butterflies to make sure they aren't hanging up on the top plate(air horn) of the carb. by the back to screws first. Take the air cleaner off and give them a tap. if they stick even the slightest bit they won't open when you put your foot down. The second thing i'd be checking is the fuel filter and fuel pressure. if the fuel filter is okay and you have low pressure then odds are the fuel pump is shot.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Thread Tools
Display Modes
