Old 11-26-2011, 11:39 PM   #1
DBear
DBear's Avatar
is this possible?
Is it possible for a 67 or 68 chevy 4x4 1/2ton to not have a K in the vin#?
DBear is offline   Reply With Quote
Old 11-27-2011, 12:25 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: is this possible?
not if it is the original VIN and originallt a 4X4
Old 11-27-2011, 07:11 AM   #3
The K "defines it" as a 4wd. The VIN is like a finger print or better yet,DNA
Old 11-27-2011, 08:19 AM   #4
cdowns
cdowns's Avatar
lots of frankenstiens and vehicles with phony and switched VIN #'s it pays to do your homework b4 spending cash
Old 11-27-2011, 10:42 AM   #5
68gmsee
Active Member
68gmsee's Avatar
These trucks are over 40 years old and there have been a lot of mechanics that have swapped engines, rear ends and made other changes when needed -like grabbing a cab or bed from one truck and swapping it to another. As a matter of fact, I'm in the market for a cab for my 69 right now and I don't know what I will wind up with.
I see a lot of trucks on craig's list where the seller says it's a certain year but the front end definitely shows a different year.
68gmsee is offline   Reply With Quote
Old 11-27-2011, 07:49 PM   #6
feller
feller's Avatar
what if it were converted? like a napco? i have read but do not remember all the other things napco did besides a transfercase and front axle?? i may be out of line just a thought. but the old cab switcharoo would also explain
feller is offline   Reply With Quote
Old 12-02-2011, 10:27 PM   #7
SS Tim
SS Tim's Avatar
The few I remember seeing were coded as expected. The factory model codes were CS or CE for conventional cabs and KS or KE for 4X4 trucks. Later trucks sometimes used an additional C like CCE or CKE (think Chevrolet Conventional Eight).
On a "period" conversion the build model and VIN would reflect the "as built" configuration. There should also be an upfitter certification plate/sticker on later trucks.
SS Tim is offline   Reply With Quote
Old 12-02-2011, 11:42 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I think the GM vehicles with NAPCO conversions ended with the '59's. GM offered the '60's with 4WD.
If you want to check and compare VIN's, look at the one on the driver's side frame rail, in front of the firewall and compare it with the one on the cab. If the digits on the VIN don't match in both places (frame rail and cab), then you have your answer. It's prpbably a replacement cab on a 4WD chassis. Chassis are different animals for the two applications, i.e., they don't interchange...bare 2WD frame for bare 4WD frame...different part numbers.
Member Nr. 2770
Old 12-03-2011, 01:46 AM   #9
72lb4x4
I think the parent company of NAPCO survived and did conversions into the late 60's, mostly on medium duty trucks, but perhaps on light trucks as well.
72lb4x4 is offline   Reply With Quote
Thread Tools
Display Modes
