Old 11-27-2011, 07:04 PM   #1
airbrusher
lowered control arms
allright i need some advice from you all i am building a 72 shortwide i have it lowered with cpp 4 inch springs and 2.5 inch billet blocks in the rear 2.5 inch spindles in front with 3 inch springs i am running boss 18 inch wheels all around. now my question is i want the front at least a inch lower but i do not want to run bags would it be feasible to go back to a 2 inch spring and run a dropped lower control arm? if so does anyone know of a good site or place that anything used could be found? thank you!
airbrusher is offline   Reply With Quote
Old 11-27-2011, 07:09 PM   #2
BuiltwithIvy
Re: lowered control arms
I would check out pb's bolt on body drop personally, drop the entire thing around another inch
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 11-27-2011, 08:32 PM   #3
oldspowered67C10
I don't see why it wouldn't work although in my experience when you combine lowered control arms with drop spindles and springs the spring pocket on the control arms starts getting real close to the ground.
oldspowered67C10 is offline   Reply With Quote
Old 11-27-2011, 09:18 PM   #4
big_al_71
big_al_71's Avatar
What he said....
I would just cut a 1/2 coil and call it a day
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-27-2011, 09:22 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by big_al_71 View Post
What he said...
I agree.
Don't combine drop spindles and drop pocket or stepped lower control arms.
Keith
Convert to disc brakes.
Old 11-27-2011, 10:44 PM   #6
airbrusher
i was wondering about everything getting alittle close prob just cut part of a coil
Old 11-27-2011, 11:27 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
chop 1/2 a coil... you won't even be able to bolt it up if you try the a arm.
Thread Tools
Display Modes
