11-27-2011, 09:26 PM | #1 |
holes to fill in the on a step side bed
Ok this might be and easy one should i make plugs to weld up the holes
or can i just filll it in with wire welder ... if i us a plug who would make a hole punch to make small plugs any ideas would be great . the holes im filling in are the holes that mounted the spair tire on the step. one hole will be covered up the new step fender... Last edited by niterider65; 11-27-2011 at 09:27 PM. Reason: edit |
11-27-2011, 10:09 PM | #2 |
Re: holes to fill in the on a step side bed
I would get a four square metal electrical box and knock out whatever slugs that you need. 1.50 at Home Depot. A little heavier gauge but it would work.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
11-27-2011, 10:43 PM | #3 |
how big are the holes? Can't really tell scale in the pic. If they aren't much bigger than trim holes, then I'd just fill em in with wire (use a piece of brass as a backing plate so weld won't stick and will have a flat backside). But, for me, much beyond 1/4", I'd cut a plug.
11-27-2011, 11:24 PM | #4 |
im guessing i would say the bigger holes are 7/16 and the smaller hole is 3/8 ..
11-27-2011, 11:58 PM | #5 |
OH - in that case I would cut a plug for both.
Thread Tools | |
Display Modes | |
