Old 11-27-2011, 09:51 PM   #1
rs72z
rs72z's Avatar
Dually rear swap question?
Anyone know how late of a gm dually rear will work in our trucks? I'm not worried about changing hangers either.
I found a good deal on a 98 rear.
rs72z is offline   Reply With Quote
Old 11-27-2011, 11:20 PM   #2
ozark
Re: Dually rear swap question?
98 wont work I already been that route unless you change spring pad location and probally other mods.
ozark is offline   Reply With Quote
Old 11-27-2011, 11:23 PM   #3
rs72z
rs72z's Avatar
I am not worried about changing spring pads. probably going to do a flip. Width is what i need to know about.
Old 11-28-2011, 12:16 AM   #4
80SPORT
80SPORT's Avatar
You do not say whether you are doing a wide track dually pickup setup or using the narrower cab and chassis rear end.
Either way you will have to modify hangers or perches unless you already have a 30 series truck
I would look for a 73-87(91 in Crewcab)rear end
If you use the dually pickup one you get a rear sway bar as well
There are lots around for not much money....you can usually find a whole truck for 500.00
the 98 can be made to fit but wheel studs and brake lines are metric
80SPORT is offline   Reply With Quote
Old 11-28-2011, 12:19 AM   #5
rs72z
rs72z's Avatar
Standard dually rear not a c&c.
Old 11-28-2011, 01:51 AM   #6
hick
I have wondered this as well because i want to upgrade to disc brakes since no one makes a disc brake conversion for the dually 14 bolts... (to my knowledge anyways)
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 11-28-2011, 02:09 AM   #7
pig rig
pig rig's Avatar
off the top of my head if I remember right the c&c rear is 48" from backing plate to backing plate and the the std rear is 52 from bp to bp I'll put a tap to both in the morning and I think where you get the different spring perch offsets is the 1/2t spring hangers on the frame are nerrower
and as far as doing a diskbrake conver there is a wright up on pirate4x4 on whats needed and how to do it on the cheep
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 11-28-2011, 08:47 AM   #8
rs72z
rs72z's Avatar
If possible can you measure wms to wms.
Thread Tools
Display Modes
