Old 11-30-2011, 02:40 AM   #1
67sss
67sss's Avatar
short water pump and alternator on passengers side, will this work? need pics
stock exhaust or headers? I"m just wondering if this would work and which brackets would be needed for the short water pump set up? Thanks!
67sss is offline   Reply With Quote
Old 11-30-2011, 05:32 PM   #2
67sss
67sss's Avatar
Re: short water pump and alternator on passengers side, will this work? need pics
Ttt
Old 11-30-2011, 05:35 PM   #3
Bert W
Bert W's Avatar
I wouldn't mind an answer to this one myself.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 11-30-2011, 05:42 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The alt on the passenger side was in the GM cars. The alt brackets were based on a long water pump. There might be brackets to do it with a short pump... but I have never seen it. Not sayin' it isn't possible.
Not to mention you have to reroute all the wiring.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-30-2011, 07:38 PM   #5
68streetrod
here is a short water pump with alt on passenger side its chrome but that shouldn't matter can get same brackets in painted
68streetrod is offline   Reply With Quote
Old 11-30-2011, 07:55 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
That's actually a long water pump.
GM cars ran short pumps on BBC and SBC thru the '68 model year.
They switched to long water pumps in the 1969 model year.
Chevrolet and GMC trucks used the short water pump thru the 1972 model year.
(also BBC and SBC)
I've never seen a factory set-up with a short pump and the alternator on the passenger side.
Keith
Convert to disc brakes.
Old 11-30-2011, 08:24 PM   #7
50bomb
50bomb's Avatar
PUt some pictures up of your engine. So we can help you. I just went through this same problem a couple days ago. I bought the chrome brackets just like one above that fits 69-81 or 85 gm long water pump. So my alt goes on passenger side.
50bomb is offline   Reply With Quote
Old 12-02-2011, 06:03 PM   #8
67sss
67sss's Avatar
here's what I'm working with. If I put(leave) alt where it is, the belt hits the ps pump for my ram assist.I have the correct short water pulley,but like I said, the alt belt will rub on the ps pump. Will a newer style pump, which I think are smaller, have the same fittings for the hoses that connect to the ram assist manifold? Also note that my Weind intake has no hole in the front to connect brackets to.
I also have 2 different sets of headers I can use, if I can make this work.
Old 12-02-2011, 06:06 PM   #9
67sss
67sss's Avatar
headers..
Old 12-02-2011, 06:33 PM   #10
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
You've got 67-68 style brackets that require the mount on the manifold.
If you go to 69-72, you can keep the driver's side alternator, as it will mount to the head, not the exhaust. Also get a shorter belt & it shouldn't interfere with the pump.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 12-02-2011, 06:35 PM   #11
oldgold70c10
Who's got steelies?
I'm looking at your pictures again and think you'll have to go long pump for the alternator to clear those valve covers
My Truck Page
My Youtube Channel
Old 12-02-2011, 06:35 PM   #12
lolife99
lolife99's Avatar
I would just use the correct 67-72 truck alternator bracket.
No need to worry about a header bracket.
These two are all you need.
(the lower bolts to the front of the driver's side head)
Keith
Old 12-02-2011, 07:01 PM   #13
my67c20
Short water pump with a bracket from Summit. Just be carefull cause the internally regulated alternator positive terminal starts to get near the valve cover, if you go that route.
my67c20 is offline   Reply With Quote
Old 12-02-2011, 07:11 PM   #14
oldgold70c10
Who's got steelies?
Are you sure? Because that looks like a long pump.
My Truck Page
My Youtube Channel
Old 12-02-2011, 07:30 PM   #15
lolife99
lolife99's Avatar
That is also a long water pump.
It's really easy to verify.
Just measure if you are unsure:
Keith
Old 12-02-2011, 07:43 PM   #16
67sss
67sss's Avatar
oldgold70c10-I had a long water pump on it when I started and the ps pump pulley wouldn't line up. As far as changing the length of the belt,it doesn't change the distance of how close it is to the ps pump...I tried.
lolife99-the alt head mount might work, but I have no bolt hole on my intake for the other bracket. Also I've tried the newer(69-72) alt bracket and the alt would hit the valve covers before I could make any belt adjustments.
my67c20- if I can get the correct belt and bracket set up to fit, what I've done in the past, is to take the 4 screws off the back of the alt. and just turn the back of the alt connections where I want them. Just make sure to use a paperclip to hold the brushes in place while you do that.
Does anyone know if the "white"(manifold block?) has the same fittings as a power steering gearbox.
Maybe I'm just beating my self up ove this, but it's alot easier to make changes now while the front clip is off.
Old 12-02-2011, 07:48 PM   #17
lolife99
lolife99's Avatar
The tall valve covers may be a problem,... but the upper bracket doesn't bolt to the intake.
It installs like below:
Keith
Old 12-02-2011, 07:50 PM   #18
lolife99
lolife99's Avatar
The long water pump set-up places the entire alternator in front of the engine.
So no there are valve cover clearance issues.
This might be your answer.
But all of the pulleys are different.
The P/S stuff is also different.
Keith
Old 12-02-2011, 07:56 PM   #19
67sss
67sss's Avatar
Is this a short pump? Would it be possible to make my setup a 1 belt system?
Old 12-02-2011, 08:04 PM   #20
lolife99
lolife99's Avatar
Yes,... that's a short water pump.
(I've never seen a 1-belt set-up)
Most truck bracket assemblies include a "add-on" P/S crank pulley, that bolts on top of the existing crank pulley.
Then a single belt drives the P/S pump.
The other belt goes around the crank, water pump, and alt. pulleys like normal.
Keith
Old 12-02-2011, 08:16 PM   #21
67sss
67sss's Avatar
I want to thank everybody for all the information. I'll see what I can come up with sat or sunday, and let you guys know how it works out. This is just the first "ram assist" system I've ever messed with.
Old 12-02-2011, 08:32 PM   #22
Billhilly
Billhilly's Avatar
Just saw this thread now. You can do anything with time and money! I changed my alternator over because it was on the 'wrong' side. Didn't want to use header bolts at all, so just drilled an extra hole in the right side head and made the bracket bolt staight to the head. These brackets aren't commercially avaliable, but I could maybe get you a set.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 12-02-2011, 08:39 PM   #23
oldgold70c10
Who's got steelies?
When it comes to long vs short, everything is different. The pulleys are different, the brackets are different, etc.
Go to the 73-87 parts board & find someone parting out a truck & get the pulleys & brackets all at the same time from the same vehicle. Everything will line up & you'll not have any clearance issues.
My Truck Page
My Youtube Channel
Old 12-03-2011, 11:33 AM   #24
my67c20
After i sent the post i realized it was a long pump. I figured there were enough experts here that would quickly point out my error. The short hit the timing cover. but i still had plenty of room in front of the radiator so i went with the long.
Old 12-03-2011, 12:09 PM   #25
bw4sale
bw4sale's Avatar
I can't believe no one has suggested this yet (or maybe I missed it), but you could pull a complete serpentine set up off a newer truck and be done with it.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Thread Tools
Display Modes
