12-10-2011, 05:33 PM | #1 |
Transmission Oil
I have a 2005 Chevy Silverado 1500. My owner's manuel recomends changing the transmission oil at 100,000 miles but I have been informed that changing the oil could cause the transmission to slip or have other problems. Has anyone else heard of this and should the oil be changed? Thanks.
12-10-2011, 05:52 PM | #2 |
Re: Transmission Oil
changed ours in our s-10 at 100k we just droped the pan and changed the filter with no issuse so far were at 120k. just dont have it pressure flushed and you will be fine
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-10-2011, 07:03 PM | #3 |
Has more rust than truck...
Drop the pan change the filter and refill. I would be scared to change one that hadn't been touched for 150k but not 100k.
12-10-2011, 09:07 PM | #4 |
I have a 2002 Olds van and the transmission is showing a p1811 code. That is a code that is set when it takes to long to shift and then it ups the pressure and you fell a hard shift. I have a good friend(my wife's cousin too) that is the service manager at our local GM dealership. He pulled the code for and I asked him would changing the fluid help. He told me not to even think about. it has 161K. He said that if I changed it, it would start to slip. I have never changed it so that is why he said not to. It will clean the clutch disc and that why it would slip.
I think it would be OK to change yours.
2001 GMC 2WD, 1998 Chevy K2500 |
12-10-2011, 11:46 PM | #5 |
I changed mine at 80K. I bought the truck used with 60K on it and by the looks of the hitch (chain hook area and receiver) and evidence that a brake controller was installed and removed... I'm pretty sure it did a lot of trailer pulling. I'm at 135K now and wondering if I should just leave it until it blows (hopefully long after I trade it in) or change it. It still shifts great.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-11-2011, 09:31 PM | #6 | |
12-17-2011, 06:54 PM | #7 |
I change the trans filter on my 99 every 75k. My pan has a drain plug, so every other engine oil change, I drain the oil out of the trans pan, but don't bother with the filter and add new trans oil. I get about 3 qts out and add 3 fresh. When you drop the pan and change the filter, you're not draining the oil in the converter, oil cooler or lines. By replacing 3 qts at a time, eventually I'm changing all the oil. I use Dex6. I have 315k on the original trans, so I think my method works.
72 GMC Sierra Grande SWB 402 BB A/C (Owned it since 1973) 99 Silverado 1500 LT with 315K miles (RIP) 2012 GMC Sierra SLT |
Thread Tools | |
Display Modes | |
