Old 12-10-2011, 07:31 PM   #1
jasonroman
jasonroman's Avatar
85 long bed=1 1/4...86 short=1 rotors??
thought i could just swap parts. now dudes telling me rotors are different.
so now i need new drop spindles??????
jasonroman is offline   Reply With Quote
Old 12-10-2011, 07:43 PM   #2
jasonroman
jasonroman's Avatar
Re: 85 long bed=1 1/4...86 short=1 rotors??
if this is the case, how soon can i get spindles to jersey???
my daily driver is on a lift with a problem. now i have a problem. thanks for any info
Old 12-10-2011, 08:02 PM   #3
jasonroman
jasonroman's Avatar
can the 1 1/4 rotors i gave dude from 85 work if i get new calipers??
Old 12-10-2011, 08:05 PM   #4
SCOTI
SCOTI's Avatar
You need the correct rotors & calipers for the spindles (either light duty 1" or HD 1.25").
If you're swapping parts, why not swap EVERYTHING that was already assembled together?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-10-2011, 08:14 PM   #5
jasonroman
jasonroman's Avatar
well, what i did, was pulled motor, and 5-7 kit i just put on the 85.
kit was 2mths old and motor was good. i pulled other parts and then sent to scrapper.
pulled control arms.....got new pitman, idler,ball joints, tie rods, and bushings.
had bushings pressed into arms and ball joints pressed in, then dropped truck to a guy to do the rest.
just got mesg about the differnt size rotors. i didnt think to measure. thought the difference was early yrs to later yrs, not heavy duty to std.
so now trucks in shop, got 2 jobs to go to monday....
didnt keep calipers. didnt think.
so can he use the pads, and rotors.....that i pulled....that were couple mths new.
and just pick up calipers and be good?
Old 12-10-2011, 09:42 PM   #6
cableguy0
Just go get calipers from the parts store for the thick rotors. They arent that terribly expensive. The same calipers were used for like 30 years. Any auto parts store around should have them sitting on the shelf.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-16-2011, 09:29 AM   #7
jasonroman
jasonroman's Avatar
Just read somewhere that the inner wheel bearings need to be changed when swapping from 1 in to 1 1/4 rotors?
Old 12-16-2011, 10:34 AM   #8
SCOTI
SCOTI's Avatar
Correct. The light duty 1" spindles utilize different rotors, bearings, & calipers vs the HD 1.25" stuff.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-16-2011, 11:44 AM   #9
jasonroman
jasonroman's Avatar
yep, forget this, im good. had bearings, rotors etc from my other truck.
good to go,
any ideas on the wobble???
Thread Tools
Display Modes
