Old 12-10-2011, 10:34 PM   #1
AustinScott
AustinScott's Avatar
Father & Son.. Stop, Drop & Roll install
So my son and I have finally got the truck back on the ground after a few weeks of converting the front end over to disc & dropping it another 2.5"
Here are some pic of the progress
AustinScott is offline   Reply With Quote
Old 12-10-2011, 10:42 PM   #2
elf w/capital T
Re: Father & Son.. Stop, Drop & Roll install
heck yeah out em to work! looks like a bunch of fun!
elf w/capital T is offline   Reply With Quote
Old 12-10-2011, 10:42 PM   #3
AustinScott
Old 12-10-2011, 10:50 PM   #4
LEX
LEX's Avatar
Looking good.
LEX is offline   Reply With Quote
Old 12-10-2011, 10:57 PM   #5
AustinScott
So the front is a bit to low now. Tires rub on fenders when I turn the wheel all the way to the left. Also the rims hit the lower control arms a bit, we will grind a bit out tomorrow for clearance.
We already cut a single coil out of the front springs a few months back, so maybe we will need to buy new front springs with a 1" drop?
Here is the thread Coil Cut Thread Link
Start - Before any mod to the front. 32.5"
Coil Cut= 30"
Drop Spindles= 27"
Old 12-10-2011, 11:28 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Looks much better. Can you move those tires to the rear and go with a shorter tire?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-11-2011, 12:35 AM   #7
Fldawg
Fldawg's Avatar
it nice to see a young fella like that learning some good trade, instead of sitting in front of a video game , keep up the good work ....looks good
Fldawg is offline   Reply With Quote
Old 12-11-2011, 12:38 AM   #8
AustinScott
currently running 275/60/R15 in front and rear...
I did notice the front end has some toe in and positive camber.
Is it possible that the positive camber is causing the tire to rub?
Old 12-11-2011, 01:25 AM   #9
SCOTI
SCOTI's Avatar
Yes, positive camber can have an impact. I agree w/N2TRUX as well & would opt for a 245 or 255/60.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-11-2011, 10:34 AM   #10
RCbowtie69
RCbowtie69's Avatar
Looking good,keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 12-11-2011, 04:31 PM   #11
scrapmetalart
Junior Member
if it only rubs at full lock it will be fine. you will not be @ full lock @ speed just slow speed.
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 12-13-2011, 01:11 AM   #12
AustinScott
Good note!
I did a "garage" front end alignment with a level and a tape measure. I had to remove pretty much remove all my shims to get rid of my major positive camber. After I did that and got my tie-rods adjust to an equal length & getting the front and back of the front tires to measure out equal. The tires do not rub anymore at full lock.
I had to clearance the lower control arms on both sides about a half inch to keep the rims from rubbing.
I have yet to drive it over 25mph tho... I need to take it for a "real" alignment before I test the waters & the new brakes.
Sure do like the way the front looks now, only thing I don't like is I cant even get my floor jack under the truck to jack it up without removing the pad.
Old 12-13-2011, 01:33 AM   #13
BuiltwithIvy
I am going to be in Liberty Hill over the holidays and am pulling my springs out to replace with bags, if you want them, come and grab em..... And if your son wants to chip in some labor it would be greatly appreciated
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 12-13-2011, 02:31 AM   #14
AustinScott
Cool man, thanks.. are they a stock spring, or a drop spring?
Old 12-13-2011, 02:52 AM   #15
BuiltwithIvy
they are stock, but if you wanted to check out what a difference cutting half a coil would make, ill be yanking a lot of stuff over over the course of a couple weeks, so except for the engine and tranny that will get pulled for a 5.3l, most stuff would just prefer to get rid of, easier than taking it to the scrap yard if someone is coming to pick it up
1930 Tudor Sedan
Old 12-13-2011, 08:12 AM   #16
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Gotta' chime in here. First, I don't have a son (two daughters that don't give a rat's rear about old trucks), but I think it's great that you're learning these skills at your age. KEEP IT UP!
Now, to the springs. I did basically the same stuff on my '70 : (See my avatar). 2-1/2" spindles and one cut coil. Too low to be practical with my front tires. It's my DD. I put the stock springs back in and have been "driving like I stole it" ever since. I would advise against a half-coil spring. You'll never get it to sit right in ths upper and lower spring pocket at the same time. I decide against 1" drop spring, mostly because I was tired of pulling it all back apart again. Probably would look better to me, but I ain't going there again. I do run a much smaller front tire ( 265/60/15).
Good luck and keep up the good work.
TobyArnot is offline   Reply With Quote
Old 12-13-2011, 09:58 AM   #17
no moa
no moa's Avatar
Nice to see the young fella helpin out! Although i'd made him pack the bearing by hand! lol Truck looks great
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 12-14-2011, 09:28 AM   #18
68Stepbed
68Stepbed's Avatar
Pic #11 is totally a "Cover me, I'm going in!" look.
Nice progress on the truck and it's good to see your sone doing alot of the work. He will appreciate it much more.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-15-2011, 12:48 AM   #19
AustinScott
thanks guys, My son is a big fan of "fun" work and not so much of "house" work
I'm going to look into getting new drop springs here real quick.
So I'm thinking a 1" spring up front and 5" in the rear.
I'll need the whole adjustable track arm & shock relocation kit, as well as new drop shock on all 4 corners.
I remember a post that someone made about "drop" shock & suggestions on off the shelf replacements that would do the trick.... anyone care to help me locate it?
Still to do is rear 5 lug axle conversion.
how about the trailing arm cross-member, you think my drive shaft will hit after the 5" rear drop? will I need to get a new cross-member?
currently this is what it looks like for clearance.
Old 12-15-2011, 01:43 AM   #20
Jeffs70
Jeffs70's Avatar
love it, great job
Jeffs70 is offline   Reply With Quote
Old 12-15-2011, 09:00 AM   #21
68Stepbed
68Stepbed's Avatar
I have a 5" rear drop and mine clears the crossmember just fine.
Matt
Old 12-15-2011, 02:06 PM   #22
LadyBird
I'm dropped 6" in the rear with no issues either. Coming from a young college student (21 yrs old) it's awesome to see your son in there helping you. Everybody has to start somewhere.
LadyBird is offline   Reply With Quote
Old 12-15-2011, 02:53 PM   #23
michael bustamante
michael bustamante's Avatar
i BAGGED MY REAR TO THE BUMPSTOPS AND THERES NO CLEARANCE ISSUES AT ALL. i JUST BOUGHT THE SAME DROP SPIDLES....HOW YOU LIKING THEM? ANY ISSUES?
1967custom
michael bustamante is offline   Reply With Quote
Old 12-16-2011, 02:11 AM   #24
Jeffs70
Jeffs70's Avatar
I agree with the rest. I doubt you will have any issues at all. I am bagged and dropped as far as I can go and no problems at all.
even my other truck is c-notched and dropped even farther with no problems.
Old 12-19-2011, 12:52 AM   #25
jayman68
Fun Stuff
jayman68's Avatar
I don't know about the post you are talking about, but Rob has a great relocation kit and some info about shocks here;
http://67-72chevytrucks.com/vboard/s...d.php?t=477839
He also has some info scattered thru his "make it handle" thread
http://67-72chevytrucks.com/vboard/s...d.php?t=419251
He suggests in the rear to do 1" or 2" blocks first and then springs to make up the difference.
Good luck, truck looks great!
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Thread Tools
Display Modes
