Old 12-11-2011, 08:55 PM   #1
newmaac
Dash pad replacement
On a 69 C-10, we are planning weld-in a patch section to repair a PO's hack job stereo installation.
I have been looking for a good source for a new dash pad to install after we fix the metal part of the dash.
I see one on the Raybucks site for about $50, but I don't know anything about their quality level.
What have others on this site used in the past when doing a dash installation?
I tried a search, but don't see any tech tips for the actual installation either.
Ideally, I'd like to weld-up the dash, replace the pad and install a new windshield and windshield rubber all as one project.
Any suggestions would be greatly appreciated.
Mike
newmaac is offline   Reply With Quote
Old 12-11-2011, 09:17 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Dash pad replacement
Here's one:
http://67-72chevytrucks.com/vboard/s...d.php?t=327177
If you type the words remove dash pad into the Google search box at the top of this page, click on the circle in front of "67-72chevytrucks.com", then click on the "Google" button you will find some threads about it. Make sure the thread is on the 67-72 truck board...
LockDoc
Leon
Old 12-12-2011, 09:02 AM   #3
dcasalena
dcasalena's Avatar
I believe there are 2 types of replacements available. One is a rigid plastic piece that sort of has the right look, but it is hard; it's usually called a dash pad cover. This one is much cheaper, and your $50 find is probably this one. The other is padded, and runs around $80 from most vendors I think. Check out the LMC catalog, they have both on page 99.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=99
I'm not recommending a vendor here, though I did get mine from LMC and am very happy with it. But the LMC catalog is a very good reference to keep around for when you need to know what goes where, and what you need to attach it with.
dcasalena is offline   Reply With Quote
Old 12-12-2011, 09:19 AM   #4
WAAF
I have one of the padded ones that I'm not use'n to bad your on the wrong coast
WAAF is offline   Reply With Quote
Old 12-16-2011, 12:03 AM   #5
timberjim36
timberjim36's Avatar
hey WAAF how much do you want for the dash pad ?
1980 crewcab dually soon to have a gen VI 454 rectangular port heads holley strip dominator crusader marine stand alone tbi setup with a TCI tcu controlled 4L80 (daily driver)
92 harley electra glide ultra classic
timberjim36 is offline   Reply With Quote
Thread Tools
Display Modes
