12-11-2011, 09:04 PM | #1 |
Got big-block?
The K25 gets FAST fuel injected and a new EZ-TCU
I thought that since I've only driven her 80 miles since the full frame off, why not throw a new FAST EZ-EFI on the 468 and lets upgrade the first-gen TCI trans controller with their new EZ-TCU controller. You can follow along on my build thread for all the details. Here's a couple of pics of the install:
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
12-11-2011, 09:39 PM | #2 |
Sierra Grande Club
Re: The K25 gets FAST fuel injected and a new EZ-TCU
Noice!
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-11-2011, 09:53 PM | #3 |
That system is awesome my best friend has it in his 70 camaro
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-11-2011, 11:40 PM | #4 |
I have been wanting to get one of those but the price is killer
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
12-12-2011, 08:44 PM | #5 |
Got big-block?
Here's a couple of pics of the new air cleaner I am going to use. For those of you not following the build, I had originally been using a '72 Corvette dual snorkle cleaner. With the 1" carb adapter plate installed and the relative flatness of the Corvette cleaner base, I didn't like how much of the throttle body and injectors I could see....trying to keep it as stock looking as possible.
So, I bought a GM restoration '67 big-block Chevelle air cleaner that has a deep dropped-base that hides most of the throttle body, injectors and sensors. I think it looks great. Here's a couple of pics of the new air cleaner, as well as a few pics of the new TCI tcu harness being installed and run down through the hole below the console. Still have a few wires to connect, then I can power it up.
12-12-2011, 09:05 PM | #6 |
I hope you like yours better than I did mine
After futzing around with it I thew it up on the shelf for a leaf blower project that will be well served by it and went with my Sean Murphy-prepped Q'Jet and the HEI. No comparison Looks good and good luck! Bud |
12-12-2011, 10:02 PM | #7 |
Got big-block?
Lol...that's funny. I took off my Sean Murphy quad for the efi.
As far as "no comparison", what specifically doesn't compare? The EZ-EFI's on some of my friends cars works great; what problems did you have with yours?
12-12-2011, 10:26 PM | #8 |
i plan on doing this, have you drove yet??? do you get better gas mil???? please tell all the details thanks
1971 rs camaro under the knife ls3 6 speed swap 1970 396 big block shorty fleet 67 clone 2010 rs/ss camaro |
12-13-2011, 12:09 AM | #9 |
x2. I've been watching these set-ups & waiting to read some 'real world' opinions of how 'easy' they really are to use as well as how effective vs a carb.
12-13-2011, 09:10 AM | #10 |
Got big-block?
Hey SCOTI! Good to hear from you. As far as my EZ-EFI install, it has been fairly easy to install...95% is just wiring and running fuel lines. I will be sure to post about the initial start-up and tuning using the hand held. I helped two friends install this same set-up on their cars; a '62 Impala SS with a radical Bill Mitchell 427 smallblock and the other was on a '55 Chevy with a ZZ502. Both installs went smoothly, were easy to tune, and have performed flawlessly. The driveability of both cars was greatly improved. I will keep ya posted.
12-13-2011, 09:21 AM | #11 | |
Looking forward to your progress reports!
12-13-2011, 01:27 PM | #12 | |
When I am on a vacation and a bolt on system strands my ass and with my wife glaring at me with the "I told you not to f**k with it!" look in her eyes then I appreciate simplicity all the more. I logged a lot of road time before I set out on the road and it tuned itself "fairly" well but it could have been tweaked better if I was able to get into it and do it but this is what appeals to most folks who don't want to drag around a laptop. I used an LC-1 wideband controller for a long time to "real world" tune my carbies so I do have a very good feel for what is happening at any which given time. Personally, it was really nothing more than a "wow" factor when I popped open the hood but aside from that. Simplicity wins me over every time. Port injection is a better scenario but still again, these are bank-to-bank setups unless you buy the high dollar sequential setups with all of the hardware and appropriate sensors and you might as well look for a donor vehicle with a setup you want to transplant and be way ahead $$-wise...but that is just me. Lots of folks don't bat an eyelash dropping $3K+ to add EFI to an older mill and that is okay too. The next (and probably very last) iteration will be a complete LS engine swap and that way I can run a factory designed late model setup with all of the OEM stuff in place and leave it be If you are not as anal as me (no one is) then you will be very happy with the FAST system Good luck! Bud |
12-13-2011, 02:26 PM | #13 |
Thanks for the feedback.
12-13-2011, 07:56 PM | #14 |
Got big-block?
Thanks for the info, Bud. I hope my system works as well as my friends. If it does, I will be really pleased.
I'll keep you guys posted on the progress.
12-18-2011, 06:27 PM | #15 |
Got big-block?
Well, a little more progress on the EFI and TCU install today. I got the wiring finished up under the dash...you can see the extra fuseblock I installed a while back for all the accessories I have installed on the truck. That extra fuseblock is an NOS 64 Chevy truck accessory block I got on ebay... it matches the factory block pretty well.
You can see the computer cable from the EZ-EFI computer on the firewall routed through the steering column grommet...this is the cable you attach to the EFI hand-held unit to manipulate the EFI settings. I also got the new EZ-TCU controller and hand-held mounted in the factory console. Only a couple of loose ends to finish up now...hopefully by Christmas day.
02-26-2012, 06:22 PM | #16 |
any updates??
07-07-2012, 11:02 PM | #17 |
Got big-block?
Wow! It's been awhile since I updated this thread. The truck is running great with the EFI! I had an issue with the TCU...it went bad, and TCI sent me a new one...that kept me from driving the truck as the trans wouldn't shift, but all the bugs are worked out now, and she drives so sweet. My buddy who wrenches at a local 4x4 shop calls her a Cadillac because she runs so good and smooth.
Thread Tools | |
Display Modes | |
