12-15-2011, 01:25 PM | #1 |
What is your winter project?
I will be painting under the truck. About 5 percent of the under side has a little surface rust. I need to fabricate steering stops for the lower control arms. Someone cut them off. I plan to install the rear C-notches without removing the bed. The biggest problem is the brake line is in the way. I will also check, and repair the rear brakes if needed.
12-15-2011, 01:33 PM | #2 |
Re: What is your winter project?
With any luck, I will get my truck out of paint. Then I can do my summer build project over the winter.
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 |
12-15-2011, 01:54 PM | #3 |
Engine swap eventually. Soon as I get time away from the soccer fields I'll swap out the oil consumption 350 wuith a new crate.
12-15-2011, 02:34 PM | #4 |
My plan is to get started tearing into my shortbox that I bought a few months ago.
RIZ |
12-15-2011, 03:16 PM | #5 |
not much of a winter here, 65 today.. but my indoor project is applying burbinga veneer to my instrument panel. and building electronic instruments and some custom led lighting control..
12-15-2011, 03:36 PM | #6 |
Right now the 59 is getting the love. 1. Re-wire 2. New exhaust. 3. Bed wood. 4.brakes. 5. 62 impala steering wheel. Then 1. alcoas and rubber on the dually 2. Spindles and hangers on the dually. By this point i should be completely broke, so i will start tearing down the 78. In between ill finish spray-bombing the travelall and rebuild the carb. Hahaha. In my dreams.
Posted via Mobile Device |
12-15-2011, 04:16 PM | #7 |
My 85 4x4 Shortbox
12-15-2011, 04:21 PM | #8 |
misshape grape
I would love to tear into mine...but can't bring myself to do it....as I love driving it.
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
12-15-2011, 04:35 PM | #9 |
getting all body work done and in primer.
My Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=484114 |
12-15-2011, 10:49 PM | #10 |
78K & 79C Jimmys
Winter is tommorrow night -13C
today was +10,but rain hmm maybe clean and sort the garage out wife thinks i hid a truck in there, just cause she can see doors
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
12-16-2011, 01:06 AM | #11 |
Depending on the work schedule finish putting the new engine and trans in my 98 crew cab then after the first of the year wire up the lights in shop,move out the 39 ford and tear into my 84lwb to swb step conversion.
12-16-2011, 03:25 AM | #12 |
When I get the K10 back soon I plan on doing some wiring fixes, and getting the engine pulled and replacing the rings and throwing on a set of 305 heads I have laying around
1981 K10 Scottsdale
305 ci | TH350 | NP208 | 60k miles |
12-16-2011, 08:15 AM | #13 |
Continue to finish my summer(2010) project.... 76-3/4
12-16-2011, 08:34 AM | #14 |
Finish this.......
crate motor in this.... Last edited by Desert1957; 12-16-2011 at 08:48 AM. |
12-16-2011, 09:55 AM | #15 |
Tearing it down, need to pull master cylinder and wiper motor before the cab is ready to come off.
12-16-2011, 12:47 PM | #16 |
GoatLube Experss
to save enough money to go home in may or june !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
12-16-2011, 02:47 PM | #17 |
I hope to get the body off the 85 and put on some homemade roller stands. Then, pull the body off my 83 and put it back on the 85 frame (after cleaning and a quick paint). This one I want to get going again soon, so I will have a operational truck for "stuff". The 85 Ext. cab will be getting a full rebuild and made pretty from the frame up David
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
12-17-2011, 11:56 PM | #18 | |
Thread Tools | |
Display Modes | |
