Old 12-16-2011, 02:36 AM   #1
JumboAMONGus
JumboAMONGus's Avatar
67 chevelle rearend in a 56 chevy truck
has anyone ever used a coil spring rearend out of a chevelle or elcamino and put into a chevy truck i have a 1956 CHEVY 1/2ton short bed millitary truck with a t-10 283 bored .125 over running an original duntov 30-30 cam i could weld leaf spring perches and put it in or thinking trying to use the mounts for a 4 link set up ? pics would be great if any one has done this before ..thank you !
JumboAMONGus is offline   Reply With Quote
Old 12-16-2011, 02:39 AM   #2
JumboAMONGus
Re: 67 chevelle rearend in a 56 chevy truck
oh and how do you add a picture of your truck ?
Old 12-16-2011, 11:02 AM   #3
pro1955
pro1955's Avatar
I have before, I cut off all the brackets and welded on new leaf spring perches. Easy and streight forward.
Truck's just for the fun of it.
pro1955 is offline   Reply With Quote
Old 12-16-2011, 10:47 PM   #4
mknittle
mknittle's Avatar
I am doing one now on a 52 GMC. But I am using QA 1 coil-overs and the rear is out of a 76 Monty Carlo I think the control arm are longer than the Chevelle otherwise the same.
i made the upper cross member and am working on the lower hangers.I have the parts cut out and tacked together for a mock up. now i have to modify them to fit the curve of the frame. I will get some pics soon.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-16-2011, 10:52 PM   #5
JumboAMONGus
thank you mknittle ,and pro1955 ,thats what i was looking for i was gonna do the spring perch but i have a camaro rearend i can use but since i got a 10bolt posi from an elcamino or chevelle for almost nothing i rather try to do a coil over or take the coil spring pads off and then mount a coil shock i would like to see pics how you welded to the frame when done ,,ill post pics to im trying to figure out how think i gotta do a photoshop first there no easy loader
Old 12-17-2011, 11:57 AM   #6
mknittle
mknittle's Avatar
It took me a while to figure out how I wanted to do the springs. The coilovers give enough room for a gas tank behind the rear end.best of all the suspension side loads are transmitted farther forward on the frame maybe causing less flex.
Mark
My GMC build.
Old 12-17-2011, 03:18 PM   #7
mknittle
mknittle's Avatar
here are the parts so far. I have the control arms apart for cleaning and re bushing.
Mark
My GMC build.
Old 12-17-2011, 07:46 PM   #8
JumboAMONGus
hey can you make me one of those front crossmember bars that what im talking about ohh yeah thats sweet ,,,cause i found the rearend came out of a el camino and it has the arms till attached to it .. that gonna fit with out having to cut the frame is the perfect way to go ,,,and i like it cause it sits inside the frame rather then the bolt on 4 link kits
Old 12-17-2011, 07:47 PM   #9
JumboAMONGus
make either flat plates off the frame for srpings or probly easier to go with coil over shocks on a crossmember
Old 12-17-2011, 08:27 PM   #10
mknittle
mknittle's Avatar
I am going to make a cross member for coilovers on mine
Mark
My GMC build.
Old 12-17-2011, 08:36 PM   #11
mknittle
mknittle's Avatar
The cross member that I made won't fit the chevelle because the arms are a bit shorter. One would have to be made to fit your application. all the parts have to be fitted pretty much one by one. so nothing binds.
Mark
My GMC build.
Thread Tools
Display Modes
