Old 04-22-2003, 04:32 PM   #1
dubie
dubie's Avatar
Axle shafts from non posi to posi
Is there any difference in the axle shafts from a posi to a non posi. I have the chance to get a posi gear set out of a wrecked 67 and I want to put it in my 72, but I wanna know if all the shafts are the same.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-22-2003, 04:33 PM   #2
bpmcgee
bpmcgee's Avatar
Dubie,
I'm pretty sure they're identical. When I was having my axles worked on, we put an Eaton posi in the pumpkin, and I don't think we had to order different shafts.
Brian
bpmcgee is offline   Reply With Quote
Old 04-22-2003, 04:40 PM   #3
dubie
dubie's Avatar
right on!! looks like I'm gonna swap to a posi !!!
Old 04-22-2003, 04:44 PM   #4
dubie
dubie's Avatar
what about the pumkin cover, will it need to be changed?
Old 04-22-2003, 04:49 PM   #5
cdowns
cdowns's Avatar
posi's work alot better with chrome pumpkin covers. if you change to posi be aware that there is a special additive that you have to use with the rear end grease
Old 04-22-2003, 04:51 PM   #6
StingRay
StingRay's Avatar
Sorry Tim but 70 and up use longer axles than 69 down housings. The only way you can use that 67 housing is to use the 6 bolt axles or get custom axles. I have heard of people re-drilling bolt patterns as well but the idea wouldn't thrill me.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-22-2003, 05:20 PM   #7
dubie
dubie's Avatar
DAMN!!! ah well I'll go get it ,along with the axle shafts and see if there are any interested buyers here. Thanks guys
Old 04-22-2003, 07:44 PM   #8
texnician01
texnician01's Avatar
If I am reading your post correctly you are just trying to see if the carrier will fit the axles? the carrier will fit into any 12 bolt truck rearend long or short and use the axles that belong with that rearend. you want to change to a posi, easy just change the carrier. the axles all have the same splines and everything and they used the same axles regardless of posi or open. you should be able to swap carriers and not have to worry about a thing. just make sure you use the thicker gear oil for a limited slip/posi in it or you will burn up the clutches. the diff cover will work just fine there was no difference. the stock cover is usually a little stronger than a chrome jobbie though.
Nathan
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 04-22-2003, 08:01 PM   #9
Rod
dubie you can use the carrier and gears from the 67 into the 72. You may get away with just swapping carriers as long as the carriers have the same range of ratio gears.
Pretty much in these truck... 307 carrier is for 307 gears. and the 373 carrier uses 373 or 411 gears assuming this is all 1/2 ton stuff which Im pretty sure you have.
The axle spline count is the same on 67-72 axles but the lenght does change in 70 to a little longer. In 71 the axles have 5 bolt pattern compared to the older 70 down version which have 6 bolt.
Gears sets have to be from a matched pair, you cant take two of the same ratio gears and use the crown from one and the pinion from another... there machined as matched sets.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-22-2003, 11:27 PM   #10
StingRay
StingRay's Avatar
Oh ya sorry about that I guess I didn't read that as thoroughly as I should have. If you are going to change gears and/or carriers you will need to have somebody do it that knows what they are doing. Setting up a 12 bolt from scratch is a black art.
Canada
Old 04-23-2003, 07:30 AM   #11
Ed ke6bnl
[QUOTE]Originally posted by texnician01
[B]If I am reading your post correctly you are just trying to see if the carrier will fit the axles? the carrier will fit into any 12 bolt truck rearend long or short and use the axles that belong with that rearend. you want to change to a posi, easy just change the carrier. the axles all have the same splines and everything and they used the same axles regardless of posi or open. you should be able to swap carriers and not have to worry about a thing. just make sure you use the thicker gear oil for a limited slip/posi in it or you will burn up the clutches. the diff cover will work just fine there was no difference. the stock cover is usually a little stronger than a chrome jobbie though.
Nathan [/B
When you say switiching carriers is no problem are you talking about also switching the pinnion.and all its spacers and crush sleeve. If you don't switch the pinnion do you have to reshim and check LASH, this is an issure I am dealing with right now. Thanks Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 04-24-2003, 03:02 PM   #12
texnician01
if you change the carrier you will have to set up the rear end all over again. yes you will have to check the lash and everything else. I havn't been to this point yet, so I can't answer many questions on how to set them up I'll have to look in a few books to do that. I just was saying that the carriers are interchangeable. whenever you change the carrier, ring gear or pinion you need to make all of the checks. Whenever you change one gear you should change them as a set. both new gears or a matched used set from the same rearend. I have had several people tell me that they are not hard just time consuming. I figure I just as well learn how.
Hope that answered your question.
Nathan
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 04-24-2003, 03:32 PM   #13
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Does anyone know where to get info on rebuilding one of these rear ends? My posi is going out and I do not have a clue. Chevy shop manual?
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 04-24-2003, 10:47 PM   #14
cb
Richman Gear has made a VHS video that is very helpfull. About $10. Summit has them. Caution: rebuild requires a lot of special bearing removal tools and a hydraulic press. Also torquing crush sleeve is a real ***** with standard 1/2 drive tools.
Craig Berland
cb is offline   Reply With Quote
Thread Tools
Display Modes
