Old 12-18-2011, 08:38 PM   #1
chevymotocross
chevymotocross's Avatar
Out of round rotor?
My friend just bought an 86 chevy c10 stepside. The LF wheel was making constant noise. Pulled the wheel and inspected the rotor. I've never seen this but the rotor is not spinning true, it hops up and down causing the noise. I recommended a new rotor for starters but is it possible the spindle is bent? Wheel bearing doesn't have excessive play.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 12-19-2011, 08:56 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Out of round rotor?
If the spindle was bent,... it would still spin true,... just out on the camber or caster.
Sounds like a cheap parts house rotor that is warped from brake heat or over torquing the lugs.
Keith
Convert to disc brakes.
Old 12-19-2011, 11:38 PM   #3
chevymotocross
Makes sense. We will see what new rotors do.
Old 12-20-2011, 01:48 PM   #4
fuzzy1nickels
New bearings would be cheep insurance also.
fuzzy1nickels is offline   Reply With Quote
Thread Tools
Display Modes
