Old 12-19-2011, 08:47 PM   #1
a2tripp
a2tripp's Avatar
doh! look at what I brought home
well I saw this and had to have it. I have no idea why. Wife thinks I am homer simpson, instead of donuts its vehicles. Anyways its rusted out but original, 67 cst with a 327/th400. runs good for the most part. Going to drive it as is but I need some help. I have no real brakes until the pedal is half way pressed and boom, the tires (front I think?)damn near lock up. Its like its getting its pressure all at once. The PO did some major work on the ALL drum brakes, mostly everything has been replaced but there is a huge problem, so... he said that it needed a new proportioning valve....well I didn't think all drums had such a thing, but sure enough they have a distribution block. So I am guessing this is what he is speaking of. He said the master cyl and booster were replaced about a year ago and the drums/ shoes/ hardware are all new. I think there was a new hose or two on the receipts. Theres good resistance on the pedal when you start to push down and the feel of the pedal is good, its just you have no real brakes until about half way down the they will lock up if you dont take your time. Can't drive it that way on the snow and ice so I need some help.
Also, the 327 has a stock 4 barrel manifold with a bad rochester on it, will a spare carter afb bolt on?
and some pics
89 GMC V3500
Alaska members check in
a2tripp is offline   Reply With Quote
Old 12-19-2011, 08:48 PM   #2
a2tripp
a2tripp's Avatar
Re: doh! look at what I brought home
some more
89 GMC V3500
Old 12-19-2011, 08:52 PM   #3
shawno72
C/10 junkie
shawno72's Avatar
Cool. I like it. I used to have a 68 cst.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-19-2011, 08:52 PM   #4
black_sheep454
I like it rust and all
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 12-19-2011, 08:55 PM   #5
doubleb's69
doubleb's69's Avatar
Is the AFB a spread bore if so then yes. If it has a stock manifold on it then it is probably a spreadbore.
Bud
doubleb's69 is offline   Reply With Quote
Old 12-19-2011, 08:57 PM   #6
50bomb
50bomb's Avatar
I know why you got it cause its darn Cool
50bomb is offline   Reply With Quote
Old 12-19-2011, 09:02 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
AFB's are squarebore carbs. So it would require an adapter to fit the stock spreadbore manifold.
Holley makes a spreadbore 650 with vacuum secondaries that will bolt right in place of the ol' Q-puke.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-19-2011, 09:08 PM   #8
shawno72
C/10 junkie
shawno72's Avatar
How much you give for it??
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2011, 09:14 PM   #9
hugger6933
nice truck Homer!JK I think you made a good find and yes the Carter AFB should fit and def will fit if it has the dual mounting holes on the factory intake you will use the inside holes most [if not all of the 300 hp and up ,I think]had the Carter AFB carb on them OE
hugger6933 is offline   Reply With Quote
Old 12-19-2011, 09:17 PM   #10
leddzepp
Moderator
leddzepp's Avatar
67 CST should have bucket seats. Look at the cab behind the seat and see if there is a brace about 12" long in the center along the top.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-19-2011, 09:41 PM   #11
a2tripp
a2tripp's Avatar
I got it for 500, because of the brakes, the body has cancer throughout but I like it and I can take the 72 off the road for longer periods of time now.
The po sold the buckets, but I am a bench person anyway, now the wife doesn't even have the tcase shifter in her way!
89 GMC V3500
Old 12-19-2011, 10:07 PM   #12
duallyjams
duallyjams's Avatar
For 500 it would follow me home too.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-19-2011, 10:18 PM   #13
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Did you tell your wife its a CST? A 67 CST! Any man in his right mind would buy a 67 CST for a price like that!!
Sounds like there is something wetting the brake pads, like brake fluid, they will keep sliding with a lot of pressure then lock up quickly.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-19-2011, 10:29 PM   #14
a2tripp
a2tripp's Avatar
ok,ok, dont flame me, but what is so nice about a 67 cst?
I know the PO, hes somewhat reputable around these parts as far as knowledge, but like I said, I dont even think drum/drum have prop valves. He was pretty adament about that being the issue. Bunch of receipts came with the truck, wheel cyl, lines, shoes, hardware, drums... I think this was an existing problem with the brakes that the po threw parts at to fix then just got fustrated.
From what I know, and its very little is that if I had a leaky wheel cyl it would be one tire, not the front (or all) engaging roughly at once. and with being drum/drum the brake should adjust themselves.
I haven't had a chance to really look at it yet but it seems that he replaced everything but this distribution block. never in my life have I had one, or heard about one going bad in stock apps.
Its weird, you go to use the brakes, the pedal feels fine, you get to a point (probally half way in travel) and the wheels want to lock up. I mean you feel like youre going to go through the winshield.
89 GMC V3500
Old 12-19-2011, 10:34 PM   #15
shawno72
C/10 junkie
shawno72's Avatar
Vintage is right on the brakes. Fluid on the brake shoes will make the brakes lock up fast. Check the wheel cylinders and make sure they are not leaking. Heck while you got the drums off just replace the wheel cylinders and front brake hoses, they are cheap. Also a leaky rear axle seal will cause the brakes to lock up in the rear.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2011, 10:34 PM   #16
bowtie72
bowtie72's Avatar
Man what a deal! I would start off by inspecting the brakes at the wheels. Check adjustment and hardware. If all that checks out I would bleed them. It would be a starting point. I have seen alot of drum brakes installed wrong. Good luck
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 12-19-2011, 10:35 PM   #17
shawno72
C/10 junkie
shawno72's Avatar
Drum/drum brakes do have prop valves. That may be the problem.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2011, 11:22 PM   #18
70cst
70cst's Avatar
on a very ride
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-19-2011, 11:23 PM   #19
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
drum/drum trucks do NOT have a proportioning valve, just a distribution block.
Pres the pedal down with your hand. Is the pedal real easy to pres and then you get reisitance 1/2 way down? You should only have free pedal travel the first 1/2 inch or so. I've seen this cause what you describe.
Old 12-19-2011, 11:28 PM   #20
Vintage Windmills
Vintage 4x4s
It not a huge deal since they aren't super rare but the CST's essentially just had more "bling" It doens't mean a lot to some people but it does to others for collectability/desirability. They had nicer trim and meant factory bucket seats, also things like special bright radio and instrument knobs, wrinkle finish glovebox door, better insulation, and some other things I can't think of right now. Your truck also has the nicer brightwork on the front end. Typically if a truck was a CST it had other nice options (not because they came with CST but because if a truck had an upgrade like that, it likely wasn't a plain jane otherwise) Your truck having a TH400, 327, Power brakes, swaybar, etc is an example of this.
Old 12-19-2011, 11:39 PM   #21
juanz1947
rusty 66
juanz1947's Avatar
Nice truck Ive always wanted to go to Alaska soon some day I hope
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 12-19-2011, 11:43 PM   #22
a2tripp
a2tripp's Avatar
right on, its funny, up here I look at how nice a truck is by the amount of rust.
The PO said the buckets he pulled out of it were pristine, sold them to a buddy for 750.
89 GMC V3500
Old 12-20-2011, 12:01 AM   #23
shawno72
C/10 junkie
shawno72's Avatar
I stand corrected. Learned something new today. Thats why I love this site. Longhorn man I just thought the block on the side of my 68 master was the same as the one on my 72. That explains why I have to change it to a prop valve when I do my front disc brake upgrade. Thank you so much for clarifying that.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-20-2011, 12:26 AM   #24
GASoline71
GASoline71's Avatar
An AFB will not mount to a spreadbore manifold correctly without an adapter. Dual mounting holes will allow it to physically be a "bolt on" but the butterflies won't be able to open.
Gary
Old 12-20-2011, 08:30 AM   #25
MARKDTN
This is where I would start also.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Thread Tools
Display Modes
