Old 12-20-2011, 10:31 AM   #1
slam59
Lowering front with only drop springs= rough ride?
I have a 74 c10 that I wanna do a budget drop job on and wanted to know if all I used were 2" or 3" drop springs in the front will it ride pretty rough? Will use flip kit for the rear. Thought about a 3-5 drop this way.
slam59 is offline   Reply With Quote
Old 12-20-2011, 10:47 AM   #2
The_BullDog
The_BullDog's Avatar
Re: Lowering front with only drop springs= rough ride?
its not so ruff as it is unbalanced. your going to wear the inside of your tires out fast. I did it for my first budget drop. best bet is a drop spindle and maybe one coil cut from the front springs.try just the spindles first if you need lower then cut one or lower springs.
The_BullDog is offline   Reply With Quote
Old 12-20-2011, 12:54 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by The_BullDog View Post
its not so ruff as it is unbalanced.....
Not if you get it aligned after its done. I agree that the preferred route is spindles first and springs second, but it's not mandatory.
If your looking for drop on the cheap, I would cut 1/2 to 1 coil off the stock spring. Do no use excessive heat, and remember that 1 coil is approximately a 2" drop.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-20-2011, 07:49 PM   #4
rwhit57
rwhit57's Avatar
When just cutting the coils sometimes there's not enough bolt to align the upper a-arm out. This can be cured with longer bolts. Don't forget to remove the bump stops and maybe the pads.
rwhit57 is offline   Reply With Quote
Old 12-21-2011, 12:52 AM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
am i the only one that had to take half my spacers out on the upper A arm and add a swaybar to keep the OUTSIDE of the tires from getting eaten?
maybe i just take corners to hard with my truck like im driving a corvette or something?....
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Thread Tools
Display Modes
