12-21-2011, 08:15 AM | #1 |
Front Bearings Good for 140mph ???
I have the stock front suspension on my truck with the stock disc brakes and wanted to know if there is a good upgrade to the front brakes/bearing. Next year my truck should be running in the 9's around 140mph and I just don't trust the small bearings in the front. I'm running 5 lug 15" wheels and would like to stay with that.
Thanks Brett Edit: I forgot to mention that my truck has a Duramax diesel in it and the truck weighs 5100lbs total. Front is 3160lbs and rear is 1920lbs. That is why I don't like the small bearings in the front.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP Last edited by bcdeutsch731; 12-21-2011 at 08:44 AM. |
12-21-2011, 09:04 AM | #2 |
Re: Front Bearings Good for 140mph ???
I highly doubt you added more weight with the swap.. than those bearings are designed for..
iirc a 3/4 ton the difference is in the balljoints.. and arms.. not the bearings.. I'd worry about the correct grease and the seal over the bearings you change the lower a arm mounting u bolts to the thicker 73 up type? |
12-21-2011, 10:05 AM | #3 | |
It would also go w/o saying (& I'm sure you've already are) but run the best bearing money can buy.
12-21-2011, 02:46 PM | #4 | |
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP |
12-21-2011, 03:23 PM | #5 |
The u bolts are thinner on the 60-66, but I think the 67+ are the same.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
12-21-2011, 03:48 PM | #6 |
Charlie Daniels w/ a Tq Wrench
Not sure about the speed ratings, but as far as weight, something to look into is
88-98 C1500 (5x5) and C2500 light duty (6x5.5) both share the same spindles and bearings. Maybe go to a parts store, pick up bearings for that application and compare. IIRC square body LCAs and the upper BJs off a 88-98 C2500 will make those spindles work for you.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
12-21-2011, 04:42 PM | #7 |
The front crossmember a-arm U-bolts for drum brake trucks are smaller vs disc brake trucks (not just 60-66). U-bolts for 73-87's are the same for C10's - C30's.
12-22-2011, 03:16 AM | #8 |
At the body shop.
When i was young and retarded. My poor old 77 got whipped hard. Had a 2.73 gear and nasty 406. And it would run 5800-6000 in high gear. And leave it there till the oil pressure went away. Still cant I survived stunts like that much less the bearings or the radial t/a's.
" That didnt make it any newer " " Dont antique the equipment " |
12-22-2011, 03:44 AM | #9 | |
12-22-2011, 05:59 AM | #10 |
~Rest In Peace~
keep the wheels up as long as possible
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
12-22-2011, 07:06 AM | #11 |
taller tires slow the bearings down
12-26-2011, 01:22 AM | #12 |
Dont hold me to it but I think your pretty safe with the stock bearings. I agree to run the best ones you can find. I only use timken bearings but Im not sure if these are the best. In general the taper wheel bearing is very robust and larger than needed in most vehicles.
Thread Tools | |
Display Modes | |
