Upholstery
Now that I have the 1999 Silverado bucket seats and the Jeep console in place in my '53 Chevy truck I am going to have carpet installed (take the seats and console back out). After that I plan on having the door panels upholstered using vinyl and the same material as the seats. Then I plan on having the area (walls behind the seats as well as the headliner done using the seat material. I read somewhere about using ABS plastic as the liner for the upholstery to be glued to. The reason the guy said that he uses the ABS is because you can heat it with a heat gun and form it to any shape you desire. He used this instead of the thick cardboard type paper because the plastic did not warp or absorb moisture like the paper product. Have any of you used the ABS plastic for this purpose?
Re: Upholstery
no but sounds like a better idea then cardboard ,,plus should be a better sound deadner too
Re: Upholstery
We have used ABS plastic for over 35 years now for this kind of stuff.
You can even press mold one off parts with it. it comes in a variety of thickness. Heating in ovens is the best way to bend it but can be done with guns or heat strips. it machines well also. You have to heat it to around 180 deg to bend and it melts soemwhere around 225 degrees or so. You can even solvent glue it together to where you can hardly see a seam. Great stuff. Don't use your kitchen oven ![]() |
Re: Upholstery
Re: Upholstery
Thanks for the information. I probably will seek help from you as I begin this project after the new year. What do you suggest using for insulation and sound deadening material to be placed between the ABS and the truck body?
Re: Upholstery
Their is so many brands now of material I lost track. Everyone is going to reccomend what they used so That may be another question to ask. I would put the material in the door not between the panel if I was doing it. There are just too many good products out there now
#7 | |
Re: Upholstery
Re: Upholstery
Where is a good place to buy the abs?
Re: Upholstery
I can get mine at a place close to where I live. I will put their link in but I am sure there are places like this all over. This particular place was recommended by a friend.
http://www.b2byellowpages.com/compan...stics-inc.html |
Thread Tools | |
Display Modes | |
