12-26-2011, 04:22 PM | #1 |
Can I use a 1/2 ton brake booster on a 1 ton?
I have the original booster and m/c assembly from my half ton project, and would like to know if I can use it on my 67 1 ton that I am swapping the rear diff and front suspension from a 87 1 ton.
Or should I just use the hydroboost assembly? Thanks for any input Pat |
12-26-2011, 08:51 PM | #2 |
Re: Can I use a 1/2 ton brake booster on a 1 ton?
They used vacuum assisted brakes on the big trucks before changing to hydaboost. The big difference in vacuum boosters are the over-all diameter & diaphragm quantity.
So, the 1/2 ton booster/mc assembly will increase the pedal pressure vs non-power brakes but it won't be comparable to a HB set-up. Whether that's good or bad is dependant on several factors (presonal preference being a main one). If anything, the mc needs to be sized based on the caliper & drum piston volume so it needs to be for a HD 3/4 ton Burb/truck.
12-26-2011, 09:32 PM | #3 |
Thanks for the input.
I think I might just go and salvage the parts for the hydroboost off the wreck in the backyard. It's good that I haven't hauled it away yet. I will say that I hate the way they (GM) mounted the front brake calipers on the 87 donor truck. They won't fall off, but what a pain to blow apart! |
Thread Tools | |
Display Modes | |
