12-29-2011, 11:49 AM | #1 |
hid's in our trucks
Anyone have them what headlight did yall use and what hid's did yall use.i like some for my 65.pics would be nice to
Posted via Mobile Device |
12-29-2011, 11:58 AM | #2 |
Re: hid's in our trucks
What are hid's?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-29-2011, 12:02 PM | #3 |
Hid's head light.
12-29-2011, 12:26 PM | #4 |
I thought they were illegal? Not that it matters to some...
<edit> http://67-72chevytrucks.com/vboard/s...d.php?t=488934
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
12-29-2011, 01:43 PM | #5 |
Gotcha...never seen them.
12-29-2011, 02:25 PM | #6 |
C10 CLUB Y QUE!
i have the headlights but not the bulbs yet!
or the ballest H4 bulb in there now |
12-29-2011, 02:51 PM | #7 |
"Where were you in '62?"
Take a gander over here:
http://67-72chevytrucks.com/vboard/s...d.php?t=395480 Posted via Mobile Device
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
12-29-2011, 04:41 PM | #8 |
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-29-2011, 06:09 PM | #9 |
I've always preached that HID's in housings made for filament bulbs are terrible, and last night I had a good reminder of why I'm so against drop in HID's. One of my friends was given a set of drop in HID's for Christmas and he installed them in his Acura. He showed them to me last night (all giddy that they're so much "brighter") and I'll have to say that they were HORRIBLE!!! They were low beam only (the ballast can't cycle on/off quick enough nor reliably enough) and they put out the worst beam pattern I've ever seen! VERY splotchy, with dim and hot spots, and zero cut off on low beam, just like a normal high beam. They were shining up into trees and overhead road signs like crazy. They also had zero down road visibility, due to all of the foreground lighting and zero control of the beam pattern to shine more light straight ahead. I followed him in my car that has 7" Cibie Z Beam headlights, 80/100 watt Hella H4 bulbs, and a 10g relay harness, and I noticed when topping a hill (the beam pattern was shining up) that my low beams had more long distance range than his super-duper HID's. On my way home he got behind me, about a 1/4 mile back, and I had to tilt my rear veiw mirror to keep from being blinded by the excessive glare.
HID's in a housing made for filament bulbs are a bad idea, and DO NOT improve lighting performance. If you want HID's, buy a complete OEM kit from a wrecked BMW or Honda S2K, or Acura with projectors and high/low beam capabilities and retrofit them into your car/truck. This is the ONLY proper way to have upgraded, useable HID lights that don't blind oncoming traffic. HID's are so bright that they have to have a very controlled low beam pattern or else they'll have excessive glare. If the low beam pattern doesn't look like this, you'll be blinding oncoming traffic.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-29-2011, 07:33 PM | #10 |
I agree. The link I posted in the thread I posted showed where to get 7" housings made for hid
12-29-2011, 07:51 PM | #11 |
The Xenarc lights are nice, but for the price you could make atleast two or three sets yourself. OEM projectors and ballast can be fit in clear lens 7" housings, and there are places that have projector bezels to hide the cut in the reflector to fit the projector. The biggest issue with doing it that way is the added depth though, and the Xenarcs may have fixed that issue.
12-29-2011, 10:47 PM | #12 |
the xenarcs have both a high and low beam, something that would double or triple the price of making it yourself for bi-xenon setups. unless you were happy with only the low beam, or used a second set of lights mounted elsewhere for highs.
12-29-2011, 10:53 PM | #13 |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
12-29-2011, 11:35 PM | #14 |
OEM bi-xenon projectors have a flap to cover half of the lens to create the low beam cutoff. A solenoid moves the flap to make the high beam pattern. Retrofitting high/low beam projectors wouldn't increase the cost since you wouldn't be buying anything extra, it's all built in together in the same projector.
12-29-2011, 11:58 PM | #15 |
yeah I know how they work, thanks for the recap. buying the bi-xenon setup costs more than the single low projector is what I was saying. although looking at ebay prices have come down quite a bit.
Thread Tools | |
Display Modes | |
