Old 12-30-2011, 11:03 PM   #1
jessewebb
jessewebb's Avatar
Gas tank swap from cab to underbed
Hey guys, have a couple questions for anyone that has done this swap or has knowledge of doing it. I bought a 69 camero gas tank. have the wire for the sending unit, anti squeak pads, float cam lock, flip down license plate. Now for the questions???
(1) will a 69 camero sending unit work with my gas gauge? are they the same ohms?
(2) should I use the trunk floor braces for the camero?
(3) also can I use the camero straps
(4) Last one. What size gas line 3\8? single line. or does it require a return line also?
Any threads or just straight up answers will be greatly appreciated, Thanks
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 12-30-2011, 11:21 PM   #2
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: Gas tank swap from cab to underbed
This guy did it , not sure his thread will answer all your questions, its been a while since I looked at it, but maybe it will help...... oh and I like this way of doing it thats why I saved this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=243181
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 12-30-2011, 11:27 PM   #3
jessewebb
jessewebb's Avatar
I'll check it out red69ss thanks for your time friend
Pete
04 325i lady's ride
Old 12-31-2011, 12:07 AM   #4
red69ss
red69ss's Avatar
no problem, make sure you post pics of the install.
1969 CHEVELLE SS
Old 12-31-2011, 01:03 AM   #5
Bert W
Bert W's Avatar
Here is one 67 Slider did. I found it in the FAQ.
http://67-72chevytrucks.com/vboard/s...d.php?t=448431
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 12-31-2011, 11:05 AM   #6
67Slider
67Slider's Avatar
I did this and I think my post will answer your ?'s but here goes...
1. The stock 69 sending unit will work with your gauges. Same ohms.
2. I didn't use the floor braces or the camaro tank straps. Pretty easy to fab up your own with some 1x1/8 steel.
3.My 67's original tank did not have a return line so I just went with a single line sending unit. If yours had two you can probably go either way, but hopefully somoene else will jump in on that.
Good luck.
Matt
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 12-31-2011, 11:17 AM   #7
jessewebb
jessewebb's Avatar
That's a big help. I'm not much of a fabracter I can get the braces and strap for around $100 I can get either sending unit. Think I'll go for the single line. Save some $ on the gas line. Thanks.
Pete
04 325i lady's ride
Old 12-31-2011, 11:25 AM   #8
67Slider
67Slider's Avatar
I couldn't get the camaro straps to work and all you have to do is cut and bend the tank straps to match the contour of the tank. I have ZERO fab skills but I pulled this one off. The steel will cost you 5-10 bucks compared to the tank straps and if I remember correctly the tank straps come straight so you have to bend them too. Just my .02.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 12-31-2011, 12:48 PM   #9
jessewebb
jessewebb's Avatar
So just pick up some straps long enough to go from one end to the other instead of buying the straps for a camero. Those would be cheaper for sure. I think I'll give it a try. Thanks
Pete
04 325i lady's ride
Old 12-31-2011, 04:04 PM   #10
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
One problem you may or may not have.
Is your filler tube going to be higher than the tank?
If not trying to fill your gas tank via the flip down license plate my prove to be difficult at best.
Good luck and let us know how it turns out.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 12-31-2011, 10:19 PM   #11
jessewebb
jessewebb's Avatar
I'll post some pics, when I get started on that part of it. just gathering parts and info right now. I just need the sending unit and the straps and the bed removed. That i'm hoping will make it much easier. I'm in the process of redoing the entire truck. I hope to have it finished by spring and ready to paint. Thanks for the advice, I will be using it wisely and defiantly asking more questions. Thanks Guys
Pete
04 325i lady's ride
Old 12-31-2011, 10:36 PM   #12
jessewebb
jessewebb's Avatar
Matt, I've had your thread saved since I bought my flip down license plate, at least 6 months ago or longer. Thats the first thing I bought. I came across the thread and thought I'd love to do that. I've seen the underbed tanks with the filler in the bed, just didn't appeal to me. I'm defiantly going to do it, may be awhile before I get to the back of it. But its on the list before it comes out the garage door. Thanks for posting that thread.
Pete
04 325i lady's ride
Old 01-02-2012, 12:49 AM   #13
jessewebb
jessewebb's Avatar
Matt, what straps did you use?
Pete
04 325i lady's ride
Old 01-02-2012, 01:27 AM   #14
Bad70sbchevy
Bad70sbchevy's Avatar
I did the same as 67Slider did, just bent some 1/8"x1" steel to the shape of the tank using a pipe wrench and a vise. As for the gas cap here's what I did.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 01-02-2012, 10:42 AM   #15
67Slider
67Slider's Avatar
I did pretty much the same thing as this. I think I bought 10 feet of 1x1/8 and went to work on it.
I gotta say Bad70 that is a sharp sub and amp install! Beats the hell out of my old school carpeted box back there.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-02-2012, 10:54 AM   #16
shawno72
C/10 junkie
shawno72's Avatar
This is the way I want to go someday. I like the contour of the tank and the idea of the flip down gas tank.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-02-2012, 07:31 PM   #17
Bad70sbchevy
Thanks 67slider, got bored with some CAD design software I got from school.
Old 01-02-2012, 09:13 PM   #18
jessewebb
jessewebb's Avatar
Thanks for the pictures, That helps quite a bit. oh and the ones of the tank to: lol. That is a bad looking speaker and amp box outfit. I'm just getting all kinds of idea's. I like the thump. Feels good on my old back.
Pete
04 325i lady's ride
Old 01-13-2012, 10:58 PM   #19
jondancer
I want a 69. Camaro tank also. Any complaints? Or does it function fine.?
jondancer is offline   Reply With Quote
Old 01-13-2012, 11:28 PM   #20
67Slider
67Slider's Avatar
I love it. No fill problems and haven't scraped it on anything...yet.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 03-20-2012, 09:21 PM   #21
KellerMAC
KellerMAC's Avatar
Ok Guys, please help me - I swapped out my fuel tank on my 72 for a 69 camero tank and mounted it but now I can't fill it - the pump nozzle keeps kicking off. Help!!!
Russ
Texas - Don't Let The Size Scare You!
KellerMAC is offline   Reply With Quote
Old 03-20-2012, 10:10 PM   #22
jondancer
Have you tried other gas stations? I hope this is easy, I'm doing the same swap.
Thread Tools
Display Modes
