Old 12-31-2011, 12:49 AM   #1
2wd73blazer
Whats involved in turning a dually into a srw?
I love the look of the 73-87 ccswb trucks. I was wondering how its done. I found a 87 cc dually longbed. I would like to know what it would take to make it a 1/2 ton shortbed cc.
2wd73blazer is offline   Reply With Quote
Old 12-31-2011, 01:04 AM   #2
nekkidhillbilly
Re: Whats involved in turning a dually into a srw?
14 bolt axle and new bed to make it srw
shortbed you have to cut the frame and shortnen it and get a shortbed vs a longbed
nekkidhillbilly is offline   Reply With Quote
Old 12-31-2011, 05:28 AM   #3
andrewmp6
How to shorten the frame http://www.73-87chevytrucks.com/lwb_to_swb.htm but you still gotta change the rear end the bed,On the front i know you need 1/2 ton spindles not sure on what else is different tho.
andrewmp6 is offline   Reply With Quote
Old 12-31-2011, 04:09 PM   #4
phishninmn
Swap the hangers in the rear also. Up front I bought a complete front crossmember but you can just swap arms and spindles
phishninmn is offline   Reply With Quote
Old 12-31-2011, 04:51 PM   #5
2wd73blazer
Is there a thread on here where someone has done this type of conversion?
Old 12-31-2011, 05:30 PM   #6
pig rig
pig rig's Avatar
its pretty easy all you need to swap is the rear end to a srw 14 bolt and swap rotors to srw'd pretty easy to do on a saturday
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 12-31-2011, 07:44 PM   #7
rs72z
rs72z's Avatar
Wish you were closer i would swap rears with you.
rs72z is offline   Reply With Quote
Old 01-05-2012, 10:26 PM   #8
2wd73blazer
Will 1/2 ton suspensions fit these trucks? I would like a softer ride than most of the heavy duty trucks ive ridden in.
Old 01-06-2012, 12:14 AM   #9
ghettoluxury
ghettoluxury's Avatar
Yes you can swap out the whole front cross member and the rear springs and hangers from a 1/2 ton truck over to your 1 ton frame.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-06-2012, 01:40 AM   #10
2wd73blazer
Do they bolt right in or is there some fab work involved?
Old 01-07-2012, 03:41 AM   #11
meter swinger
meter swinger's Avatar
Wink Re: Whats involved in turning a dually into a srw?
Best shot at success is to snatch a .5 ton donor. I have both sitting @ my house. just have not been able to bring myself to cut up my 38k mi dually and hose up two trucks. Hahaha
meter swinger is offline   Reply With Quote
Thread Tools
Display Modes
