Old 04-24-2003, 03:10 PM   #1
jcalisi
Question power brakes
I was at O'Reily's the other day and priced a master cylinder with power for $109. I was wondering what else I would need to convert my manual over. Any special rods between the brake and booster or will the stock stuff work? I'm going to keep it drums for now, unless for some unknown reason I can't...
Jon
1968 C10 Custom
jcalisi is offline   Reply With Quote
Old 04-24-2003, 03:21 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
You will need the correct firewall bracket and the rod to the pedal is different from your stock non-power rod. Best bet is to get these items used and bolt on your new booster and master cylinder.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-24-2003, 03:32 PM   #3
jcalisi
Would they be the same on a 68 - 80's?
Jon
1968 C10 Custom
Old 04-24-2003, 03:47 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
The firewall bracket is unique to 67-72 as is the rod.
Old 04-24-2003, 03:50 PM   #5
jcalisi
Off to Ebay I go. Thanks for the info. Oh by the way you don't have the listed parts for sale do you?
Jon
1968 C10 Custom
Old 04-24-2003, 06:33 PM   #6
Scottri
Scottri's Avatar
It's a pretty easy upgrade if you find the original bracket, rod, pedal rod and booster. I got mine as a complete setup and it took a couple of hours to clean and paint everything and replace it. I exchanged the original booster for a rebuilt one and put a new master cylinder in just to be safe. It's really pretty easy. You will need a new master cylinder since the rod between the booster and the master is different.
Scott
1969 GMC 3/4 Ton Long Bed Fleetside
350, 4 speed manual, P/S, P/B, Edelbrock 1406 Carb
Beaverton / Portland Oregon
Scottri is offline   Reply With Quote
Old 04-24-2003, 06:42 PM   #7
woodyjeff
You will probably have to buy a whole assembly off of ebay with a master cylinder and booser that somebody took off all together, I never saw them seperate. Thats what I just did a month ago and got a whole set up for $50 and to my suprise the booster was even good. I had to clean everything up and repaint but it that was know problem. To hook them up is no problem just bolts up to old holes and you will need to add some brake line because the master cylinder is moved forward. Also be sure you have the right master cylinder and booster. In 71 they went to a different master cylinder and different mounting on the booster.
70 Custom-10 LWB
woodyjeff is offline   Reply With Quote
Thread Tools
Display Modes
