01-04-2012, 11:32 AM | #1 |
Power Brake Experts Needed!!!!
My recently acquired '72 SWB 4x4 has factory power brakes but my pedal is "hard". My engine vacuum at idle is around 18", the check valve holds vacuum, my calipers aren't frozen-up, the booster looks new, my PCV valve is working properly. I have read some tests for brake boosters and mine seems to pass the test where with the engine off you pump the brakes a few times to use up vacuum, then hold the brake pedal down and start the engine. The pedal does go down a little bit, which should indicate a functional booster.
What am I missing? |
01-04-2012, 01:49 PM | #2 |
Re: Power Brake Experts Needed!!!!
I'm not an expert by any means, but have you checked the prop valve to make sure it is the correct type, and/or is working correctly? That's the only thing I don't see a reference
to in your post. Good luck. Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
01-04-2012, 01:56 PM | #3 |
Mark,
Thanks for your input! I didn't look closely at the proportioning valve but it looks like a factory part and the plunger in the front was working when I replaced my brake fluid. Dan |
01-04-2012, 02:04 PM | #4 |
Could it have an inline check valve that is in backwards?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
01-04-2012, 02:08 PM | #5 |
I'm no expert either and I don't know exactly what you mean by "hard". My power brakes are hard too but that's a good thing. I've found that the pedal should go down about 1/4 to 1/3 of it's travel and basically lock up the wheels at that point. I'd be more concerned if they were soft and the pedal was going down slowly while sitting and holding the brake.
01-04-2012, 02:21 PM | #6 | |
01-04-2012, 02:30 PM | #7 |
Ahhh I understand now. Little slow on the uptake at times. Yes, you apparently have a bad booster since you seem to have good vacuum at the carb base. I don't know if it would help but you could experiment with taking the vacuum line off the carb, plug it and see if it changes your brake situation. If not, you probably have a booster issue.
01-04-2012, 05:00 PM | #8 |
My 71 just started to do that last weekend. The first thing I thought about was the booster going bad since the pedal wasn't mushy. I did some checking and found a small split in the vacuum line...Hello! I replaced the line and it still was no better. I checked the check valve and grommet...Good. Took it out for a drive and heard the rotor squeal ever so slightly so I pulled off the rear drums and found a leaking wheel cylinder. I replaced it and bled them off. Still no better so I replaced the booster. Still no good, so I completely blocked all the vacuum ports from the engine except to the booster. I still have a hard pedal and I'm completely out of ideas.
I'll bet by this point you thought I had a solution for you. |
01-04-2012, 06:01 PM | #9 |
Dan swap out the booster it sounds to me like it has gone bad. I put a "good" booster on the 68 a year ago and it had a hard pedal, swapped to a new booster and now the pedal feels correct.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
01-05-2012, 09:11 AM | #10 |
Any other thoughts? Brake pedal/linkage binding, internal master cylinder leak, wrong part installed, is 18" vacuum sufficient, etc.???????
01-05-2012, 09:12 AM | #11 | |
01-05-2012, 11:05 AM | #12 |
Pull the vaccuum off of the booster (make sure you plug the leak, ). If it still feels the same, then you have a booster problem.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-05-2012, 01:45 PM | #13 | |
The symptom is a brake pedal that requires more force than usual to apply the brakes. It almost feels like the shoes or pads are glazed. This weekend I'm going to rebuild the calipers, install new pads and shoes and flush the entire system. |
01-05-2012, 01:46 PM | #14 |
01-05-2012, 01:49 PM | #15 |
As coincidental as this may sound, it has happened to me more than once with re-manufactured parts.
01-05-2012, 02:47 PM | #16 |
Definitely sounds like a booster problem. Since you said" newly acquired" I'm going to assume it has done this since you've had it and is not a new problem? I would try another booster, preferably a known good one (original GM if you have one) I've seen bad remans.and aftermarket (China junk) right out of the box.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-08-2012, 12:47 PM | #17 | |
01-15-2012, 11:14 AM | #18 | |
I just finished rebuilding my entire brake system. I replaced the vacuum booster a couple of weeks ago and today I replaced the rotors, calipers, wheel cylinders, pads, proportioning valve, master cylinder, drums turned and shoes/pads. I completely flushed and bled the system. My brakes still feel the same (Hard Pedal, no mushy). I'm beginning to wonder if I might have got a bad booster. Anyone else have any thoughts?? |
01-15-2012, 11:20 AM | #19 | |
01-15-2012, 11:36 AM | #20 |
Is it possible to use a hand-held vacuum pump to determine if inadequate vacuum may be preventing the booster from working? My thought would be to remove/plug the vacuum line from the manifold and plug my vacuum pump into the hose that leads to the booster check valve. I would then pump the pressure down to say 25" then try the power brakes. If the pedal feels more "normal", I would have more confidence that I should concentrate of finding a potential vacuum leak rather than changing brake parts.
Any thoughts? |
01-15-2012, 02:27 PM | #21 | |
The engine is fresh and at 2500 Ft elevation, mine is at 18in. The vacuum will vary with elevation. I also have no vacuum leaks. A few weeks ago I washed the truck and just after, I noticed the problem. The brakes have worked fine for many years so I figured it could be just wet rotors from the wash. A few minutes of driving told me different. I really think I just got a sub standard re manufactured booster from NAPA. I'm going to replace it next week and I'll let you know how it works out. |
01-15-2012, 02:55 PM | #22 | |
01-15-2012, 03:05 PM | #23 |
laying low
Just a thought. The plastic connector at the booster that the vacumn line hooks to is also a check valve to hold some vacumn after the engine has died and prevent booster damage if the engine backfires.
If that check valve is stuck it may not be allowing vacumn into the booster to assist the brakes. It is available through parts stores separately. Pull that valve off the booster leaving the hose attached and start the engine. It should be sucking air. If not you've found the culprit. quick look found this in the Dorman parts http://www.dormanproducts.com/p-9590-80190.aspx
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 01-15-2012 at 03:24 PM. |
01-15-2012, 05:38 PM | #24 |
The one I took off was gold zinc. The one I replaced it with was bare, blasted and I was told it was a Bendix. Both are identical shape and size and both have no identifying markings.
01-15-2012, 05:40 PM | #25 | |
Thread Tools | |
Display Modes | |
