01-09-2012, 03:10 PM | #1 |
1967 swb air ride
My truck has all coil spring. Would it be simple to bag it.
Posted via Mobile Device |
01-09-2012, 04:31 PM | #2 |
Happy to be here
Re: 1967 swb air ride
yes
01-09-2012, 04:33 PM | #3 |
What all would be involved. Would I have to cut and notch the frame. New to air bags here
01-09-2012, 06:25 PM | #4 |
needs more $$$
Notching the frame isn't necessary, but would get you lower in the rear. Lots of great info on this subject already posted. Do a few searches and see what you come up with. I try not to automatically steer people to searches, but it's actually needed so you can figure out what you want before you start. There's now a few different ways to go from mild to wild so it's required to do some homework before spending the $.
N2TRUX...love the new profile pic!
1970 2wd Blazer |
01-10-2012, 03:32 AM | #5 |
Notching depends how low you want it and wheel size.If you don't want to cut up the bed you can use a small bolt in notch that will get it pretty low with 15 inch rims.
01-10-2012, 11:48 AM | #6 |
Happy to be here
Its a very broad topic that can have many indepth answers. If you want some input, please offer some of your own. We need to know a LOT more about your objective besides wanting to bag your truck.
Spend some time researching all the great information this forum has to offer. Come back armed with knowledge, and details about what you want. We will be glad to help those that help us.
01-10-2012, 11:55 AM | #7 |
Just really starting to look into it. Basically would just like to be able to lower it when I'm not driving it. Don't really care if I can work each bag separately or not. Don't really wanna notch the frame.
01-10-2012, 12:41 PM | #8 |
Happy to be here
So your looking to add bags with a small budget? You can run bags in the rear with a Schrader valve to fill them. I recommend you run them separate to prevent air transfer when cornering. You will need 2 bags, 2 Schrader valves, and some DOT air line.
You don't "need" to c-notch, but I suggest you consider while your doing the bag set up.
01-10-2012, 12:45 PM | #9 |
Not really small budget. And if I bag it there going front and back. My main concern was with my truck having all coil springs would it be kinda just changing springs to bags and running air lines tanks and valves.
01-10-2012, 01:01 PM | #10 | |
Search for your specifc vehicle & the info listed should give you a decent idea of what's needed. You should isolate each bag independently otherwise the truck will lean agressively during any turning/leaning because air can/will shift from one side to the other.
01-10-2012, 01:08 PM | #11 |
you can be into a basic complete kit for around 1710.00 which would be the ridetech brand which would include the cool ride kit front and rear and there arc4000 basic 4 path compressor kit. The entire kit is a dirrect bolt in, the most time consuming part is running the air line and wiring. If you have any questions feel free and ask!
01-10-2012, 01:10 PM | #12 |
Ok thanks. That's what I was wondering if it would be more of an unbolt and bolt back in
01-10-2012, 01:17 PM | #13 |
absolutely! it is something that can definately be tackled in a weekend with a friend, the 63-72 Level 1 kit is one of the most popular kits due to the ease of instalation... depending on the current condition tear down may take longer that the actual replacement. I just recomment taking your time installing the fitting s and running the airlines. This kit is a 4 path system so you wont have to worry about the said airflow transfer
01-12-2012, 03:00 PM | #14 |
I just did this to my truck checkout my build thread all the details are in there. Very straight forward deal..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Thread Tools | |
Display Modes | |
