01-09-2012, 09:22 PM | #1 |
Help with trans mount...
I put my motor and trans in place but it looks like the trans crossmember is about an inch further back from the 4l60. Is this normal?
What has to be done to fix this? Which rubber mount should i use? I have the one from the 4l60 but not a 350 one. If i buy an aftermarket transmission crossmember, with i also have to move it and drill new holes in the frame?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
01-09-2012, 09:45 PM | #2 |
Re: Help with trans mount...
I used the 350 rear trans mount and it bolts up to the 4L60E. I lucked out and my transmission bolted right up in the factory holes without moving the crossmember or changing the driveline. I read other posts on here where others had to move the trans crossmember back and drill new holes and had to have a driveline made up. If I am correct, if you buy an after market crossmember it will have the same bolt pattern as the factory one.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
01-09-2012, 09:52 PM | #3 | |
01-09-2012, 09:59 PM | #4 |
I used factory trans crossmember. Placed motor and transmission
then bolted crossmember to trans and marked for new bolt hole on the frame. Then drilled the new holes. I only had to drill 2 holes as 2 of the holes aligned with factory holes. I then had a newer 4l60e yoke placed onto my driveshaft. The 4l60e yoke is the same spline as older trans just it's about an inch longer whch made up the diffrence for me. Posted via Mobile Device |
Thread Tools | |
Display Modes | |
