Old 01-09-2012, 11:04 PM   #1
66folks
305 v6 question
I am in the process of tearing a 305E v6 down, I am trying to remove the crankcase ventilation filter housing. I have not been able to get it removed and dont want to damage it. Has anyone ever removed this before and have any tips on how to remove it. thanks
66folks is offline   Reply With Quote
Old 01-09-2012, 11:24 PM   #2
MusicMan70
MusicMan70's Avatar
Re: 305 v6 question
From the Jolly 6066 GMC website and credit goes to Lewis Matkin; here is his response;
"Jim, this is Lewis Matkin. That strange housing on the driver's side of the
rear of the block is a filter, a crankcase ventilation filter. It unscrews the
top half from the bottom half and exposes a cartridge air filter. I hope this
answers your question. Welcome to the group!!!!"
A great source of info for these unique engines! .....Hope that helps
Cordially,
Lewis Ellis Matkin, Jr.
Dade City, Florida
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 01-09-2012, 11:26 PM   #3
66folks
Re: 305 v6 question
I have the top part unscrewed I'm looking to remove the bottom portion of it. Sorry I didn't clarify that prior.
Old 01-09-2012, 11:38 PM   #4
MusicMan70
MusicMan70's Avatar
Re: 305 v6 question
found this as well.
Good morning Jake,on our 63 the crankcase filter canister is a two piece unit,
the top unscrews off while the base remains in the crankcase.I was'nt sure how
it worked,and I thought I had to pop the whole canister out,but that was'nt the
case. It appears to be a common occurance that these filters were neglected
judging by some of the comments that I have read.The one on our truck has never
been changed.
Michael Conner-Live OakFl
Jake Groby is a member and may have the real answer about it's removal.....Henry
MusicMan70
1961 GMC Suburban
Old 01-10-2012, 12:10 AM   #5
66folks
Re: 305 v6 question
MusicMan,
Thanks for the info, I have been looking at his page for info but havent found exactly what I have been looking for.
Old 01-10-2012, 12:18 AM   #6
MusicMan70
MusicMan70's Avatar
Re: 305 v6 question
Jolly says it's a pressed fit and...
It's a tight fit, but its just pressed in. It may be stuck after 40 some odd
years, but you can work it out. Spray some stuff like WD40 on it, let it sit
for awhile, the pry up on the base. The canister will unscrew in about the
middle so you can change the filter element, NAPA #2718.
I have removed two from old engines, but they were out of the trucks. Good
luck.
"Jolly" Goodfellow
Northern Utah
MusicMan70
1961 GMC Suburban
Old 01-10-2012, 01:55 AM   #7
Corts60
Just here to tinker
Corts60's Avatar
Re: 305 v6 question
Scrape where the canister meets the block to get away the grime and soak it with PB Blaster for about a day and then carefully twist and pull it out. Might require some love from channel locks or something similar.
Old 01-10-2012, 08:00 PM   #8
duallyjams
duallyjams's Avatar
Re: 305 v6 question
Yeah soak it and soak it then soak it some more I destroyed the last one that I did.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-10-2012, 10:42 PM   #9
jbgroby
jbgroby's Avatar
Re: 305 v6 question
Yep, Scrape it clean if the heavy oil, spray the PB blaster or such let it soak. Using a light rubber mallet, tap it back and forth a bit then pull it up. My unit was built with the downdraft tube. Slightly fidderent but you had more to grab onto.
Jake
jbgroby is offline   Reply With Quote
Old 04-01-2014, 12:40 PM   #10
ahaynes106
ahaynes106's Avatar
Re: 305 v6 question
Thanks. I have been searching for days on info about removing one of these and finally found this thread. I assume getting it back in is straightforward, maybe a light tapping with previously mentioned mallet?
ahaynes106 is offline   Reply With Quote
Old 04-01-2014, 04:37 PM   #11
newbe351
Re: 305 v6 question
Yep. Mine just pushed/pulled in and out......
newbe351 is offline   Reply With Quote
Old 04-02-2014, 06:51 PM   #12
ahaynes106
ahaynes106's Avatar
Question Re: 305 v6 question
Ok...soaked in PB Blaster for 24 hours. Can't get a good grip with my hand due to lack of clearance between engine and firewall. With top screwed off, I can grab the wall of it with channel locks and wiggle it, but wiggling and pulling as best I can it is not budging. I have not tried prying from the bottom...again, not much clearance with it in the truck. So any more tips before I destroy it? LOL.
Thanks guys!
Thread Tools
Display Modes
