Old 04-25-2003, 12:45 PM   #1
ScottH
ScottH's Avatar
Help! Master cylinder question
I recently bought a 68 which had been previously converted to 5 lug all around with disc up front. I haven't driven the truck (usually helps to have a motor first), but previous owner (not the one who converted it) said the brakes worked fine.
It appears to have the original booster and master cylinder in it working with the front disc brakes. I'm a little concerned that this master cylinder, and possibly the proportioning valve, aren't the right ones for disc brakes. I reason I believe it may be the original master cylinder is because it is the small style (same size reservoirs).
If anyone can shed some light on this any info is appreciated. Also how can I tell if the proportioning valve is the right one?
Thanks!
ScottH is offline   Reply With Quote
Old 04-25-2003, 01:39 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
The prop valve will have a smaller diameter line leading to the front brakes if its a disk prop valve.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-25-2003, 03:55 PM   #3
Southpa
Southpa's Avatar
Yes, the original master cylinder (for drums)will have both fluid reservoirs equal size. The disc style M/C has forward reservoir larger. Booster shouldn't be a problem but when replacing the master cyl. don't go with the single hold-down clip variety, especially the remans. I went thru 2 that leaked out the cap. Get the beefier one with the 2 hold down clips for the cap.
And also, you will need the prop. valve for a disc setup. They are hard to find and I'm not sure if later model trucks (73 on) use the same one.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-26-2003, 10:24 PM   #4
ScottH
ScottH's Avatar
Thanks for all the info.
So will the drum master cylinder not work with the disc brakes? It is hooked and working as far as I know. Will it not work correctly?
Thanks again.
Old 04-27-2003, 12:25 AM   #5
Southpa
Southpa's Avatar
More stopping power is required in the front than the rear when running discs (more pressure needed to push calipers than wheel cylinders, I guess). You can use a drum M/C on front discs but won't be as effective as the disc M/C. The larger front reservoir, working with the right proportioning valve, ensures you get the right proportion of braking power between front and rear.
Original 350/TH350
Old 04-27-2003, 11:37 AM   #6
ScottH
ScottH's Avatar
Thanks for all the help!!!
Old 04-27-2003, 03:03 PM   #7
lukecp
Formerly yellow72custom
lukecp's Avatar
I have a equal size MC on my truck, a '72 C10 with factory power disk brakes. When i bought the truck, the MC that was on it had a larger rear resivour, but the one i replaced it with has equal sized resivours. I don't think the brakes work as good as they should, could that be a reason? The guy at the parts store assured me that even though the MC's looked different, the new one would work just fine. This guy has lots of experience and usually knows his stuff....but could he be giving me bad advice?
Oh yeah, the original MC had one bail hoop holding down the cap, and it was pointing from the front of the truck to the brake booster. The one on it now has two bail hoops holding down the cap, and both point from the fenders to the motor.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 04-27-2003, 10:27 PM   #8
ScottH
ScottH's Avatar
Update
Ok, I finally got the chance to check and I do have a larger line going from the proportioning valve to the rear brakes. So should I change the master cylinder to have the larger reservoir in front?
Thanks.
Old 04-28-2003, 07:00 AM   #9
Ed ke6bnl
dito dito, when reading your response I thought I wrote it. That is the exact experience that I went through with my bos truck. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Thread Tools
Display Modes
