04-25-2003, 03:59 PM | #1 |
rocker replacement help
Does anyone have a couple pics of how to weld in the inner and outer rocker? I have both pieces and want to get them on the truck this weekend.
Oh, and does the rocker have to go on before the new cab corner?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
04-25-2003, 05:32 PM | #2 |
Almost Satisfied
dubie, I'm no expert but here is how I plan to do mine. I will put the doors back on the cab and get the new rocker in place and tacked where it should go base on the body line with the door. I will then install the rocker. My inner rocker is part of the new floor pans.
I want to make sure the doors fit and have good seams all around before hacking and welding anymore on the floor or corners. Good luck and let me know what you learned. I know others will chime in.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
04-26-2003, 09:29 AM | #3 |
Red
ttt
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). |
04-26-2003, 09:34 AM | #4 |
Yah the inner part should be attached to the floor pan, then its just a matter of checking alignment of the door, make sure that the bottom spacing between the rocker and door is even across the door bottom.
The rockers were originally attached with spot welds so you might want to drill some holes in the rocker then plug weld them to attach the rocker to the body. IMO the cab corner should done before the rocker Last edited by Gee_Emm; 04-26-2003 at 09:40 AM. |
04-27-2003, 08:27 AM | #5 |
1969 Custom 30 wrecker
Must be alot of us doing rockers lately! I just replied to another post and Im doing a pair myself.
I prefer to do the rockers first. Tack in place, put door back on and make sure gap is good at bottom, then fully weld in. From there, you can do the cab corner or any floor repairs.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
04-27-2003, 10:34 AM | #6 |
I would say that the cab and fenders should be on the frame when doing rockers because the cab will have a nice gap around the door but then the fender could have a super nasty gap up front. It happned to me and it sucks having to do stuff Twice !
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-27-2003, 11:13 PM | #7 |
Be sure to tack weld some braces in place before starting..........helps to keep the alignment in place.....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
04-28-2003, 08:00 AM | #8 |
I didn't have any problems with the cab spreading or alignment problems. If your trucks are anything like the ones here in Pa, you've probably been driving around with hardly any rocker left for years anyway.
I woudn't recommend doing any repairs like this unless the cab is on the frame and with fenders on.
Thread Tools | |
Display Modes | |
