Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-16-2002, 11:04 PM   #1
trukman1
Post WTB: Crossmember/4X4/TH400/205
Want to purchase a crossmember for TH400/NP205 w/o catalytic converters. Am installing in 69 but need unit from later model since using '77 front driveshaft which has larger CV joint than old style. Hope this isn't too confusing. Thanks, Gary
1967 K30 461/TH400/Np205/D60/14FF/BDS
MTZ 375/75/16 on 16x10 Pro Comps
trukman1 is offline   Reply With Quote
Old 02-18-2002, 01:49 AM   #2
Mikes72
Post
Gary, have you spent any time over at www.ColoradoK5.com ? They have some informative boards and lots of parts for sale. I found out some neat stuff about my '78 K10 SWB. Hope this helps.
1972 Cheyenne Super LWB.Ochre/White with Olive Interior. Originally 402/400, Air, Houndstooth, Tilt. Installed .060 454, Comp 280H Cam, Performer Intake, Casting #781 Heads, 9:1 Compression Ratio, M/T Valve Covers, Heavily Modified 800 cfm Q-Jet, Moroso Bluemax Cap, Wires and Looms,5" K&N Air Filter, 2 1/2 Aluminized Exhaust with H-Pipe and 40 Series FlowMasters dumped. Professionally Built TH-400 with Shift Kit. 3.07 Posi Track Rear End, 5" Auto-Meter Monster Tach with Shift Light, Clarion CD, Infinity Speakers, Progressive 15x9's with 275/60R15, Tinted Windows, Lund Premier Soft Tonneau Cover and Personalized Oklahoma License Plate "MIKES72"
1978 Chevrolet 1/2 Ton Short Wide Bed. 4x4 "Spot", but not for long. Might just paint it one color some day! 350/4-speed.
1980 Nordic 18' Jet Boat.Named "JUST ADD WATER" 454/Dominator Pump. Installed bigger cam, Single Plane intake and Holley 750 DP, with Harwood dragster scoop, and a Place Diverter. Now GPS'D at 82 mph!!!!
Mikes72 is offline   Reply With Quote
Old 02-19-2002, 03:34 PM   #3
trukman1
Post
Mike, Thanks for the tip...I'll see what they have! Gary
Old 02-20-2002, 12:51 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
Post
72 didnt use any larger of a joint than any later ones did that ive ever seen, dont know that a 73-up crossmember will fit in a 69-72 frame, thye wont on 2wd ones at least, cant say for sure on 4x4
Fast68Chevy is offline   Reply With Quote
Old 02-20-2002, 11:24 PM   #5
trukman1
Post
Fast, my '69 came with what I think is called the Rockwell style CVJ wherejoint at the end bolts directly to the front output shaft of the transfer cse (came with the Rockwell T-case). The Saginaw style unit as used in the '77 I got it from uses a flange connected to that last universal joint that then bolts to the t-case. THis CVJ is larger in diameter than the one originally on the truck. Italso doesn't clear the crossmember. I have modified the crossmember to see what general shape I will need and it looks a lot like a unit my friend had in his '79 K30 with TH400. Thats why I'm looking for that crossmember and as far as I can tell from measurements he sent it should be correct width. Always helps to share info. Thanks, Gary
Thread Tools
Display Modes
